General => Open Discussion => Topic started by: salty on November 06, 2014, 09:52:35 PM
Title: DIY Vox VFS2A switch help
Post by: salty on November 06, 2014, 09:52:35 PM
Hi,
I jsut bought a Vox Nightrain G2 combo amp and am planning a footswitch build for it.
Here is a diagram I found for it:
(http://s5.postimg.org/edr7o9z1z/VOX_VFS2_A_Wiring_Diagram.jpg)
I am building this is a 1590A and would like to add a feature that I am not sure how to wire.
The amp has two channels that will be switchable by footswitch one. There is an LED that indicates that the switch has been engaged. What I would like to do is use a bicolor LED to show green when the switch is not engaged and red when engaged. I have the extra position on the switch for this, but I do not understand how to do this without closing the circuit...It appears that closing the circuit is what changes the channel on the amp. Is there a way to engaged the green side of the LED without closing the circuit? Maybe a transistor in the circuit? I am a newb when it comes to this and I appreciate any help that you guys can give me.
Salty
Title: Re: DIY Vox VFS2A switch help
Post by: danwelsh on November 07, 2014, 04:17:42 AM
I built a footswitch for my Hughes and vettner head a while back......I had to use a stereo jack. Not sure if your amp would be the same but it may. Trs footswitch is what it's referred to as.....hope this helps you
Post by: salty on November 07, 2014, 04:06:44 PM
Hey danwelsh,
Thanks for the reply! I went ahead and built it out to standard spec and passed on figuring out how to use the bi-color led. IT does use a stereo jack and I got it all working. I am going to etch the enclosure tonight...my first attempt at etching an enclosure. Wish me luck! :)
Post by: mherrera3626 on December 03, 2014, 02:26:50 AM
I finished building this using LED's. I used the same wiring setup with a 1/4 inch jack. Works like a charm with my AC15C1.
Post by: sjaustin on January 13, 2021, 02:19:11 PM
Necro-bump!
When I was building mine, I did not find any of the diagrams clear enough, so I made one of my own. I'm sharing it here in case someone else finds this thread in the future.
(https://i.imgur.com/NHZ98rE.png)
Post by: redkurn on October 21, 2021, 03:34:16 PM
Thanks sjaustin!
Buddy needed this.
Post by: Zerro on October 21, 2021, 06:40:34 PM
It is important what power is at pins going to footswich. It will tell you what resistor you need serially with LED and how to use it - as connect or disconnect for activating fx. Do you have some schematic diagram? In your first post wasn't it.
