Has anyone tried a blender pen for enclosure labeling & art?
no but I want to. One of the Amazon reviews claims it works on metal... can't imagine it being any worse than using the freaking iron.
Very cool. Think I'll pick one of those up. It's for laser-toner use, so it might actually work for etch resist. Neat!
Looks interesting, I'll order one today and report back
Very intersting, I'd assume it works with color laser printers as well.
Looks cool. The reviews on Amazon are mixed, but almost all the bad reviews are for the shipping and not the product, so it's a bit hard to tell. One of the reviewers mentioned that xylene and a brush will work just as well. Xylene's pretty cheap at a hardware store.
From what I have seen, it can work with color and B&W. I believe its possible to do this with straight xylene as well. It might be cheaper to buy a container of xylene or acetone if you plan on a bunch of builds this way.
The images I have seen online indicate that it doesn't always make the cleanest transfer, but if you want a little roughness to your look, it would work.
Quote from: diablochris6 on December 03, 2014, 09:45:01 PM
I just tried it with acetone and it didn't work very well. I just got a faint ghost of a transfer. Could have been my technique though.
Quote from: RobA on December 03, 2014, 09:46:43 PM
Yikes. Acetone is what I use to dissolve toner.
Quote from: jubal81 on December 03, 2014, 09:49:49 PM
Yeah, me too. That's why I figured I'd give it a try. My printer's toner might be part of the problem too. It's one of the infamous Brother models.
Straight xylene does work, Ive used it (I prefer pnp blue which I have at work). Make sure you use it under a hood, or with a lot, a lot of ventilation; a small spill out of the jug will make you rather high.
looking at the video it doesn't transfer toner completly.
In my expirience if the toner isn't completly transfered to the enclosure so that no toner is left on the paper, it won't work as an etch resist.
I hope somebody proves me wrong, im tired of all the sanding and ironing and cursing because one half of one letter hasn't transferred well so i have to start all over again. :'(
I found this for making your own solution.
Distilled water + isopropyl alcohol + Glycerin
My local art supply store has them for $3cdn versus the $5.50us on Amazon.com or the $14cdn on Amazon.ca, check around if you're looking to buy one.
https://www.currys.com/catalogpc.htm?CATEGORY=CHARTPAK_AD_MARKER_BLENDER
http://www.amazon.com/Chartpak-Ad-Markers-Colorless-Blender/dp/B0026HC7GU/ref=cm_cr_pr_product_top/179-8876159-6522001
Book i have says to make sure to get the xylene markers as the alcohol versions won't work for toner transfers. Also says xylene and a brush will do the job but the markers are much more convenient.
For colour transfers, the colours get transfered in the reverse order of how they were printed so sounds like the colour transfer would look quite different from the original and be much less intense.
