Projects => Tech Help - Projects Page => Topic started by: jkokura on December 06, 2014, 10:17:57 PM
Title: Moodring weird issue
Post by: jkokura on December 06, 2014, 10:17:57 PM
So, I'm working on a Moodring, and I have the most bizarre issue. I'm hoping some of you have some idea where I should start. I rarely can't find a solution on my own, so it's a major puzzler for me. I did spend about 3 hours on this issue so far.
Anyway... my Moodring PCB is exhibiting the following behaviour:
1. With power and all chips in, the 9V power rail drops down to about 5V.
2. VB drops down to about 2.5V
3. The Reg is putting out about 4V
The weird thing is that when I remove the 5V Regulator, everything goes like this:
1. The Power rail is up to about 9.3V
2. VB is up to 4.65V
3. Obviously theres no REG in so I don't get any regulator readings.
I've resoldered, triple checked every thing, and I'm pretty confident in my ability to see these sorts of things. I just need someone to give me some idea on what it could be.
Title: Re: Moodring weird issue
Post by: madbean on December 06, 2014, 10:26:12 PM
Try these two things: remove D2 and/or jumper out R33. See if either of those fixes your issue. If not, possibly another regulator.
Post by: midwayfair on December 06, 2014, 10:27:17 PM
What are you powering it with? Check the value of R33 to make sure it's 10R. However, it looks correct when you've got the regulator out, so I suspect that's correct.
If you pull JUST he PT2399 and leave in the regulator, does it help, or raise the voltage at all? It's not exactly practical to pull the brick ...
PUll D2 as well [woops, Brian beat me to it ...]
I'd also try replacing the regulator. I had some bad ones from Tayda a while back, so they do exist.
Post by: madbean on December 06, 2014, 10:40:19 PM
If D2 is bad that could certainly mess up things. It's not really necessary---just added protection for the regulator. But, a bit of overkill too.
Post by: jkokura on December 06, 2014, 10:47:49 PM
I just verified that my Regulator(s... I've tried several) are working properly on a breadboard. I lifted one side of the D2, and it's not in circuit any more.
Neither seems to be the issue.
What perplexes me is that the issue only shows up with the power applied. It's strange, because without the Regulator in, the issue goes away. With all the chips out, there's no issue. But as soon as I put the regulator in it goes weird.
I've tried three different Reverb blocks. I've tried 3 different regulators. The ICs don't seem to be the issue, but I'll try swapping the PT2399, because I don't think I've switched that.
Post by: madbean on December 06, 2014, 10:53:28 PM
What about with the regulator in and just the belton brick but not other ICs? What do your voltages look like then? That's the one with the highest current draw, obviously.
Post by: jkokura on December 06, 2014, 10:58:43 PM
Quote from: madbean on December 06, 2014, 10:53:28 PM
Regulator and brick in, drops to 5.6V
Post by: jkokura on December 06, 2014, 10:59:44 PM
I get continuity between the in and out of the reg when it's in and powered. No power or reg, everything checks normally.
Post by: blearyeyes on December 07, 2014, 08:17:07 PM
Ever hear of any bad bricks?
Post by: madbean on December 07, 2014, 11:30:17 PM
Kinda stumped on this. Do you happen to have an LM7805 instead of the L05?
Post by: midwayfair on December 07, 2014, 11:47:16 PM
If you're powering it with a regulated 9V supply all the time, you can drop the voltage with some LEDs and diodes instead of using the regulator.
Post by: danwelsh on December 08, 2014, 01:10:42 AM
Quote from: midwayfair on December 07, 2014, 11:47:16 PM
Wish I would have known this when I fried my one and only regulator I had a while back (instead of waiting 3 weeks for some to come in)......awesome thinking man
Post by: madbean on December 08, 2014, 10:11:20 AM
Possibly if C17, 18, 29, 30 or 37 were bad (the decoupling caps on 5v) it could cause the voltage to leak.
Post by: jkokura on December 08, 2014, 04:34:23 PM
Quote from: madbean on December 08, 2014, 10:11:20 AM
I'll try replacing them.
