Projects => Tech Help - Projects Page => Topic started by: Lionspaw on December 20, 2014, 10:34:18 AM
Title: Retrograde not working help! Fuzz on max
Post by: Lionspaw on December 20, 2014, 10:34:18 AM
Hi there,
As outlined in the subject, I've built the retrograde (but not wired it up in its enclosure yet - I'm just at the testing stage), and everything seems to be working except that fuzz is on max! And rotating the fuzz pot does nothing to the sound. I've replaced the fuzz pot AND transistors Q1 and Q3, incase it was those - a friend said it might be one of those causing the problem. But still no luck! I should say the volume and octave both seem to work, it's just that the fuzz sounds like it's at maximum all the time.
Has this happened to anyone else?
PS. I should add that the PCB is the August 2012 version (according to the pdf) if that helps?
