Projects => Tech Help - Projects Page => Topic started by: KevinK on January 06, 2015, 07:48:22 AM
Title: Bacon Bits boost question
Post by: KevinK on January 06, 2015, 07:48:22 AM
I was looking for a transparent boost for the internals of a guitar I'm making. I assume one could hook the out of the guitar before the jack, and put the boost circuit in between to knock it in and out of the circuit.
I won't be using an LED, so one of those and the resistor connected to it will not be needed. I was going to put a 500k multi-trim pot in place of an external pot. Going to set it once, and leave it. Same with the "warm" switch. Going to use a board mount single DIP switch. I want the most CLEAN boost I can get.
I was also wondering, since I am already in possession of one, would a 100uf tantalum cap work in place of a 100uf electrolytic? I'm sure it would be fine. Just asking.
Any advice offered will be welcome.
Title: Re: Bacon Bits boost question
Post by: drolo on January 06, 2015, 10:05:04 AM
The tantalum cap will be fine for power filtering.
Post by: midwayfair on January 06, 2015, 02:23:41 PM
What's the voltage rating on the capacitor and what are you planning to use for a power supply?
Post by: KevinK on January 06, 2015, 06:44:49 PM
20volt. 100uf on the tantalum. Using a 9v battery.
Post by: midwayfair on January 06, 2015, 07:30:24 PM
Quote from: KevinK on January 06, 2015, 06:44:49 PM
You won't need it when using a battery. A battery doesn't have any switching noise or rectification to smooth out. Power filtering capacitors are for wall warts. :)
Post by: KevinK on January 06, 2015, 11:35:35 PM
So just revert back to the original design as far as the one chip goes?
Post by: KevinK on January 07, 2015, 11:28:26 PM
Anyone know what parts I wouldn't need using a 9v battery?
I am still going to buy the board, I'll just use jumpers to bypass what I don't need.
Any help would be appreciated.
Post by: midwayfair on January 08, 2015, 04:03:44 AM
Quote from: KevinK on January 07, 2015, 11:28:26 PM
OMIT, not JUMPER. Neither of us mentioned the charge pump chip, so why would you suddenly think you were omitting that?  :o
You don't need the 100uF power filter capacitor with a battery because that capacitor is there to smooth out ripple created by an AC-to-DC power supply adapter. You do need the charge pump because it supplies appropriate power to your op amp (not to mention that if you leave it out, pin 4 of your op amp will not be connected to anything -- look at the connections on the schematic).
Post by: KevinK on January 09, 2015, 05:32:09 AM
Of course you can't remove that IC. If I implied that, it was not of my intention. It's needed to supply the + and - 9 volts to the op amp. I used something similar using a 555 timer chip.
So the rest, other than, the 100uf cap is needed?
I know even with batteries we'd use diod protection in case the battery was installed improperly.
I wish I could get board results like this at home.
Post by: midwayfair on January 09, 2015, 05:01:08 PM
Quote from: KevinK on January 09, 2015, 05:32:09 AM
Yes, everything but the 100uF, which you can add if you want (it won't hurt anything) but you don't NEED. And yeah, including the diode for polarity protection is a good idea still. :)
