Projects => General Questions => Topic started by: luks999 on January 08, 2015, 10:49:40 AM
Title: Deadringer II pots...
Post by: luks999 on January 08, 2015, 10:49:40 AM
hi
i ordered the deadringer, and just realised it doesnt use normal pots... should read the doc more carefully :(
does anyone know, where to order the correct pots in europe?
just dont wanna place an US order just for some pots...
maybe im going for the regular pots and use some wires... but its not the most "clear" way
thanks
Title: Re: Deadringer II pots...
Post by: Tremster on January 08, 2015, 11:04:42 AM
Musikding has the rotary switch, Banzai the others - except one, I don't remember which. For that I had to place my first Smallbear order.
But if you throw in some other parts that are hard to get in Europe it's not so bad. Shipping wasn't too expensive, and it was qiuck.
Post by: luks999 on January 08, 2015, 11:16:48 AM
the rotary was pretty easy to find, musikding and uk-electronic has it
and of course because there are not much others
the build doc says the cut pot must be plastic shaft.. disadvantage of the plastic shaft is, that it doesnt mount the pcb to the enclosure (no metal screw)
i gues for example, thats the right one for the 4 other pots?
http://www.banzaimusic.com/Alpha-9-PC-DET-500k-log.html
Post by: Tremster on January 08, 2015, 12:07:05 PM
Quote from: luks999 on January 08, 2015, 11:16:48 AM
This one is detent, it's not the right one.
I guess they have all the right ones now, I'm pretty sure thy didn't have the 20kW back then:
http://www.banzaimusic.com/Alpha-9mm-50k-log.html (http://www.banzaimusic.com/Alpha-9mm-50k-log.html)
http://www.banzaimusic.com/Alpha-9-PC-ANG-20k-W-Taper.html (http://www.banzaimusic.com/Alpha-9-PC-ANG-20k-W-Taper.html)
http://www.banzaimusic.com/Alpha-9-PC-ANG-500k-log.html (http://www.banzaimusic.com/Alpha-9-PC-ANG-500k-log.html)
http://www.banzaimusic.com/Alpha-9-PC-ANG-100k-lin.html (http://www.banzaimusic.com/Alpha-9-PC-ANG-100k-lin.html)
Post by: luks999 on January 08, 2015, 12:31:55 PM
thanks so much, tremster ;)
im gonna order from sb anyway, because i need some tropical fish caps...
so what does detent mean?
sb has following:
http://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-right-angle-pc-mount/
http://smallbear-electronics.mybigcommerce.com/alpha-single-gang-9mm-right-angle-pc-mount-11-detents/
they look same to me. the desc doesnt say anything
Post by: luks999 on January 08, 2015, 12:32:48 PM
and youre right, shipping doesnt cost much, but with taxes it may...
Post by: Tremster on January 08, 2015, 12:35:27 PM
You need the first one, without detent.
Detent, if I'm not mistaken, means the pot has a STOP point in the centre of the taper, but maybe some native speaker can comment on that.
If you just order some small bits that will fit in an envelope you probably won't have to pay customs and tax. I didn't have to.
Post by: luks999 on January 08, 2015, 12:51:26 PM
so i got the right ones ;)
thanks tremster, you helped me a lot :)
Post by: TGP39 on January 09, 2015, 05:12:54 AM
Hey guys. Detent simply means there is a tiny notch that helps the user locate where they are when turning the pot. For example: a center Detent pot will have a notch at the half way point (12:00). The Detent doesn't stop you from continuing your rotation. It's just a way of easily getting to the 12:00 location quickly. Hope this helps.
Post by: luks999 on January 09, 2015, 09:02:03 AM
ahhh, ive experienced such pots, but never heard or was familiar with the english term "detent" ;)
thanks steven ;)
