All EQ controls and Master working, but the gain is not functioning. With the gain off, I get clean signal, but it quiets as I turn up the gain. I've already checked wiring, components and whatnot. Here are my voltages:
Q1: D= 9.02 G= 0.12 S= 0.00
Q2: D= 5.90 G= 2.61 S= 3.13
Q3: D= 5.90 G= 2.63 S= 3.15
I though Q1 numbers looked odd, tried swapping another BS170, same result.
Schematic attached.
What zener diode are you using for z1 and is it oriented the correct way?
I've been trying to learn more about this circuit today. Since Q1 is a BS170 (N channel JFET), then the gate regulates the flow of electrons through the N channel. Since your gate voltage is practically zero, no or very little current will flow through the JFET. It looks like the only reason you have 9 volts on the drain is because it is directly linked to the B+ voltage source (though I am not positive about this). So the question becomes why do you have no voltage on Q1 gate? Perhaps your bias voltage is not hooked up properly? Do you get any voltage readings on R1? Or Z1? Also, could you get a voltage reading on pin 1 of your gain knob? (Turn the gain knob to 9:00) when you take this reading. Hopefully, we can get this circuit fixed because I would love to hear it. ;D Steve.
Thanks, Steve!
I am using 9v1 zener diodes for both.
I measure 0.11 on pin 1 of the gain pot. One the diode I am getting 0.11 (cathode) and 0.00 (anode). R1 is also measuring 0.00.
Ok. You're not getting any bias voltage. I want you to check that R17 and R18 are the correct resistors. Also check that C10 and C14 are oriented properly and are the correct Caps. Steve.
Quote from: TGP39 on January 10, 2015, 09:56:54 PM
Thanks, again. I appreciate your help so much.
I verified my resistors are correct. I did not have a 62k, so used a 56k with a 6.8k (62.8k total). Caps are the right value and orientation. I also hit these all with a the tester. I have 9v at C10 and 5.16v at C14. I have 9v at R17 and 5.16 at R18.
Here's a pic and the layout, if that helps. (Note: I have an extra row at the bottom for a ground bus.)
(https://dl.dropboxusercontent.com/u/13215910/Web%20Images/20150110_163831a.jpg)
(https://dl.dropboxusercontent.com/u/13215910/Web%20Images/Catalinbread%20Rah%20Rev%202.png)
Anthony, you have two 22nf box caps (223j100) on the upper left hand side of the board. These two caps should be 2.2nf (222j100). I still don't think that is the issue, but let's change those caps to the correct part. Steve.
Son of a biscuit!
Ok. Installed the 2n2 caps and rechecked Q1 voltage, no change.
I notice that the layout has 4 1M resistors, but I can only find 3 in the schematic. (R1, R2, R3). Not sure if it matters, but something I just saw.
This is something Ivlark says about the gain control:
The gain pot in this is effectively a pre-gain volume control (attenuation). It dumps signal to ground in the same way and in the anti-clockwise position only the 22K resistor is stopping the whole signal being dumped to ground. So the more you rotate clockwise, the greater the signal you hit the gain stages with. Are you sure the mosfets are ok? If you've socketed them it may be worth just swapping them to see if any have been damaged. They are very susceptible to static.
Want to try swapping Q1?
Also, do you have a track cut beneath the far left 1M resistor? That one is easy to miss. Steve.
Also make sure the link right next to Q1 is correct. I can't tell, but if that link is one notch lower, that will steal away your bias voltage from Q1 and pin1 on your gain pot. Steve.
I have tried swapping the FET, with same results. I actually swapped Q2 and Q1, and got identical results in both positions from the swapped FETs, so I feel confident that they are both functional in both positions.
I do have the cut beneath the 1M resistor, and my link next to Q1 appears to be correct.
Steve, thanks for all your help. You've really gone above and beyond on this. I'm going to recheck everything tomorrow with fresh eyes.
Hey Anthony, helping you helps me learn as well. I'm going to try and build this and see if I can learn much more about this circuit. I wanted one of these pedals anyway. If you get the chance, take a picture of the flip side of the board. I'd like to see your pot inputs and see where they go. Keep me posted. Steve.
Quote from: TGP39 on January 11, 2015, 11:21:24 PM
Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I honestly am not sure where the problem was, but I knifed my cuts for the third time, and scraped every last millimeter of bare board on the bottom side and somewhere it fixed a short. I am up and rocking! It sounds great!
Steve, thank you again.
Glad you got it going. If you get a few minutes can you post your voltages now that you got it working? I have one of these boxed up that I was pretty underwhelmed by and would love to see how far my voltages are off.
Thanks
That is GREAT news Anthony!! How's it sound?
Steve
Quote from: selfdestroyer on January 12, 2015, 03:01:30 AM
Thanks
I will crack it back open soon and get new numbers for you. I boxed it and rocked it earlier today, but I am waiting for my yellow LEDs to arrive so I can put the finishing touches on the enclosure and do a build report.
Steve, I really like the sound, and the eq on this is one of my favs on an overdrive. Playing through my vox, with a Les Paul gets some very nice Zep tones. Its not a high gain overdrive by any means. Its very reactive to how you play, guitar volume, and picking technique. I tried a boost (SHO) in front of it and didnt like it. I dont know if it will play well with other overdrive/distortion pedals. I will be experimenting a lot with it, though. I recommend it! I even asked Haberdasher too fab a couple boards for me to keep handy.
Thanks
Cody, here are those final numbers for you:
Q1 D= 5.72 G= 2.73 S= 3.35
Q2 D= 5.71 G= 2.71 S= 3.34
Q3 D= 5.70 G= 2.72 S= 3.33
Quote from: AntKnee on January 12, 2015, 11:27:44 PM
Thanks so much, I will pop mine open tonight and give it a check.
Cody, are you getting pretty much the same voltage readings on your RAH?
Steve.
Sorry, I was out of town for work and away from toys. Here are my voltages.
BS170's
Q1 D= 5.8 G= 5.2 S= 3.7
Q2 D= 5.8 G= 5.2 S= 3.6
Q3 D= 5.8 G= 5.2 S= 3.7
I used the "Prince Albert" layout by plesur @ FreeStombox
http://www.freestompboxes.org/viewtopic.php?f=7&t=16922&hilit=RAH&start=40#p190077 (http://www.freestompboxes.org/viewtopic.php?f=7&t=16922&hilit=RAH&start=40#p190077)
Cody,
Did you match your fets or pick certain ones for this?
I've got a Prince Albert populated i'm testing and while it sounds great it doesn't quite have the "amp pushed to limit" feel I remember getting from a real RAH I tried. I don't have any more BS170's around to try so.. before I order some thought I'd ask.
Koko
Quote from: angrykoko on January 15, 2015, 09:20:54 PM
Cody,
Koko
It was so long ago when I built this I can not remember, but I can pull the transistors out tonight (since I socket-ed them) and get the gain settings of them and see if they are matched. Its really not that gainy for me either but with with my Gibson SG and the Naga Viper in front of it, it comes alive. I really want to re-box the RAH with my Naga, I have attempted a few times but I get side tracked and never get it done.
Thanks Cody.
Steve.
Fet gains
Q1 VGS(ON) 2.298v
VGS(OFF) 1.580v
Q2 VGS(ON) 2.364v
VGS(OFF) 1.637v
Q3 VGS(ON) 2.305v
VGS(OFF) 1.584v
FWIW, I did not match my BS170's, and I used the tagboard vero layout.
