My stage fright is pretty noisey to begin with (anyone disagree with this statement- maybe somethings wrong). but its way noiseier when I try to daisychain it with one effect... when I use my 1 spot on its own without daisychaining it its a lot quieter... its still noisey but less noisey with an isolated power source.
Anyone else have this same or differenet experiences to share?
I hadn't noticed any difference in mine with daisy chaining or not but it is fairly noisy which I was going to ask about.
Quote from: Luke51411 on January 24, 2015, 12:07:33 AM
heh, well did you try running an isolated power supply?
Mine is dead quiet and I use it in a high gain environment. With the Regen cranked it has some swoosh, but nothing in the way of hum, buzz, or clock noise. I daisy chain it with a 1 spot with various effects.
Have you got the stagefright in series signal chain into the amp front end, or is it parallel in an effects loop?
Quote from: Torgoslayer on January 25, 2015, 04:16:11 PM
I get swoosh noise most of the way through the balls pot. I have a godlyke adapter and haven't had power supply noise issues with anything else. I didn't install the cap that is optional to tame the highs. I guess I need to try that next time I open it up.
i just have a major difference between isolated and daisy chained power supplies. wondering if anyone else has experience this
