General => Open Discussion => Topic started by: midwayfair on January 27, 2015, 04:34:16 AM
Title: Okay, how do I mount a dual LED?
Post by: midwayfair on January 27, 2015, 04:34:16 AM
No bezels for these exist! Very frustrating.
Title: Re: Okay, how do I mount a dual LED?
Post by: rullywowr on January 27, 2015, 04:45:31 AM
Quote from: midwayfair on January 27, 2015, 04:34:16 AM
Picture?  The dual LED's I am familiar with are two colors in the same 5mm epoxy housing...
Post by: Muadzin on January 27, 2015, 10:10:18 AM
For a 5mm dual colored LED this usually does the trick: http://www.musikding.de/Mounting-Clip-convex-for-5mm-LED
Unless you mean something else that is.
Post by: Govmnt_Lacky on January 27, 2015, 12:13:44 PM
A little snow day humor Jon?  ::)
Post by: midwayfair on January 27, 2015, 01:35:24 PM
Quote from: rullywowr on January 27, 2015, 04:45:31 AM
It's a 3mm dual LED. http://www.ebay.com/itm/20-Pcs-3mm-Dual-Bi-Color-Red-Green-diffused-3-Pin-LED-Common-Anode-/170926357126?pt=LH_DefaultDomain_0&hash=item27cc013a86
Post by: pickdropper on January 27, 2015, 01:40:07 PM
Quote from: midwayfair on January 27, 2015, 01:35:24 PM
You could probably bend the legs back some and use a snap-in Fresnel lens.
But the easiest thing would just be to tack it in place with a bit of super glue.  If you wanted to protect against potential shorts, you could hold it in place with a glob of RTV.
Post by: GermanCdn on January 27, 2015, 01:46:01 PM
FWIW, for the 5mm dual LEDs I use standard bezels and I cut a line between the two holes on the plastic insert so I can pass all three legs through the insert. I put a little bit of shrink wrap on the base of the legs to keep them from shorting out.  Works fairly well.
Problem with the 3 mm LEDs is that the outside leads extend beyond the footprint of the base, so this technique doesn't work unless you start doing a bunch of leg bending at the base.
Post by: Muadzin on January 27, 2015, 02:36:28 PM
Would this work for a 3mm dual LED?
http://www.musikding.de/Mounting-Clip-for-3mm-LED
Post by: midwayfair on January 27, 2015, 05:26:26 PM
Quote from: Muadzin on January 27, 2015, 02:36:28 PM
It's a little too small. The leads of the LED would push it out and it wouldn't fit in the hole drilled for it.
I guess I am going to have to glue it to the enclosure, unless I want to use a big 5mm bezel.
Post by: Govmnt_Lacky on January 27, 2015, 05:37:51 PM
The primary design for those LEDs is PCB mount with a stand off.
You will be hard pressed to find a bezel for them.  :-\
Post by: davent on January 28, 2015, 01:18:17 AM
I've had good luck with just a friction fot of 3mm led's. drill the initial hole with a 1/8" bit, paint and clear the enclosure the holes now too small for the led, hand ream with a 3mm drill bit and you have a nice tight fit howevr the led wiil protrude to far through the enclosure so i add a ~1/16" thick, 1/8" nylon washer as a spacer between the enclosure and led. Also slightly countersink the hole on the outside of the enclosure to enhance appearances.
Can always add a touch of super glue to secure.
Have done pcb mounted led as well.
(http://i216.photobucket.com/albums/cc305/davent/IMG_4269.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_2862-2.jpg)
(http://i216.photobucket.com/albums/cc305/davent/IMG_2751.jpg)
Post by: midwayfair on January 28, 2015, 02:19:24 AM
Dave, those all look really good. Good idea with the washer. :)
Post by: nieradka on January 28, 2015, 08:18:00 PM
Yeah, I just drill the hole a size small, then file it out until I can jam it in. I havent had one fall out yet, and Im rough with stuff.
