Hi, first post here.
I just finished the Upper Decker project and must agree with other users that sounds AWESOME. BUT it's been mentioned several times that the boost provides not a satisfactory effect over the effect (pun intended).
What I propose - I don't know if anybody did this before- is this: first, put jumpers instead of R28, C32 and C33. Then, remove completely C29, R33 and R34. Then, change the original values of the next components into the proposed ones: R7:1.5M, R29: 430K, R30:43K, R31: 390 ohms, R32: 1OK, C30: 100nF, C31: 100nF.
What you've got with this? Yeap: the beloved EHX LPB Booster! I have not done the change yet, but tonight I will and will let you know the results only if you ask.
What do you think about this guys?
Cheers!
...what did you come up with? did it work?
Did you ever get around to this mod?
A One Post Wonder! ;D
^^^^^^Brilliant!!^^^^^^^
We should assume if you do this mod, you are transported to an alternate reality without access to the Madbean forum.
