Projects => General Questions => Topic started by: playpunk on January 29, 2015, 03:48:22 PM
Title: Drill Press
Post by: playpunk on January 29, 2015, 03:48:22 PM
Hello folks. I have been thinking about buying a small drill press, and wondered if anyone here had used any of the small cheap "benchtop" presses. I don't have much room, so I'm looking for the smallest practical press for drilling enclosures and pcb's
Title: Re: Drill Press
Post by: mandrewbot3k on January 29, 2015, 04:37:10 PM
I have an old 1930's/40's craftsman drill press, so I can't really comment too much on the small ones. But have you tried using a drill guide? Something like these....
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=drill+guide
Post by: playpunk on January 29, 2015, 04:42:09 PM
This is what I'm looking at: http://amzn.com/B00HQONFVE
for $50 more... might be enough but I can't tell.
Post by: icecycle66 on January 29, 2015, 05:20:29 PM
I have the Skil brand version of the Wen drill you are looking at.
I cuts trhough enclosures fine, even with step bits.
I haven't tried drillin PCB holes with it.
Post by: selfdestroyer on January 29, 2015, 05:22:16 PM
This is the one I use and love it.
http://www.amazon.com/Craftsman-Bench-Drill-Press-Laser/dp/B005D1QJ92/ref=sr_1_1?s=hi&ie=UTF8&qid=1422551985&sr=1-1&keywords=craftsman+table+top+drill+press (http://www.amazon.com/Craftsman-Bench-Drill-Press-Laser/dp/B005D1QJ92/ref=sr_1_1?s=hi&ie=UTF8&qid=1422551985&sr=1-1&keywords=craftsman+table+top+drill+press)
I have had it about 2 years and use it solely for enclosures and PCBs. I would definitely buy another one if this one crapped out at this point.
Post by: mandrewbot3k on January 29, 2015, 05:29:14 PM
For small stuff, like pcbs, i like to use my dremel with the dremel press like this... (http://ecx.images-amazon.com/images/I/51E9BWDEDVL.jpg)
I attached a picture of my craftsman. not sure if itll work.
Post by: rumbletone on January 29, 2015, 06:26:00 PM
I use a dremel 'workstation ' press. Not the most solid piece of gear, but it works for drilling PCBs and for pilot holes for enclosures.
Post by: playpunk on January 29, 2015, 06:28:23 PM
I don't have a dremel.... so I don't think the Dremel press makes much sense. I got a $25 gift card for doing a survey to Amazon, so I'm thinking about how much closet space I want to dedicate to a drill press. That's right, I might put a drill press in my closet.
Post by: icecycle66 on January 29, 2015, 06:42:23 PM
Uh, okay.
Make sure you line that bad boy with trash bags.
Shavings get everywhere.
Post by: playpunk on January 29, 2015, 07:15:07 PM
It's a workbench in a closet, so not that bad. The shavings issue might get me in trouble, though.
Post by: bela1961 on January 29, 2015, 09:01:15 PM
Speaking from personal experience, get a small shop Vac and police your work space so it always looks reasonably tidy. It keeps the non-believer's at bay.
Post by: playpunk on January 29, 2015, 09:07:54 PM
I have a door I can shut.... That helps a bit.
Post by: pryde on January 29, 2015, 09:42:58 PM
I have used the 10" skil for light duty stuff for years. Tt has been great.
http://www.amazon.com/3320-01-120-Volt-10-Inch-Drill-Press/dp/B003LSSS0W/ref=sr_1_1?s=hi&ie=UTF8&qid=1422567449&sr=1-1&keywords=skill+table+top+drill+press
Post by: davent on January 29, 2015, 11:06:02 PM
I've a small bench top similar to the ones posted, made in China branded King for sale in Canada, indispensible and used for far more then pedal building, don't know why i waited so long. I don't like it for drilling PCB's, have setup with a Dremel for that.
Post by: Leevibe on January 30, 2015, 01:52:13 AM
One thing that separates the better presses from the cheaper ones is the quality of the quill. Good ones will have less runout, and therefore will drill cleaner, rounder, more accurate holes. Probably not critical for pedal building. I'm currently using a Ryobi cordless hand drill. It's got an annoying amount of wobble but I use it anyway. It does make it tough to get LED bezels to snap in nice and tight. I used to own a nice Jet 14" drill press and it ran very true. Wish I still had it.
