Projects => General Questions => Topic started by: garfo on January 30, 2015, 01:08:46 PM
Title: pt2399 lock up
Post by: garfo on January 30, 2015, 01:08:46 PM
Ei there. I have a Sea Urchin that I've built that doesn't always put out delay. Sometimes the delay just stops working. Could this be a case of the Chip delay locking up?
I've even rebuilt the board and made a tidier build and still sometimes I don't get delay.
Is there a way of fixing this?
Title: Re: pt2399 lock up
Post by: sturgeo on January 30, 2015, 01:09:54 PM
Have you connected both pins 3 & 4 to GND on the PT2399??
Post by: copachino on January 30, 2015, 01:35:50 PM
Quote from: garfo on January 30, 2015, 01:08:46 PM
Looks like a bad pt2399
Post by: midwayfair on January 30, 2015, 01:46:44 PM
Quote from: sturgeo on January 30, 2015, 01:09:54 PM
It's this.
Post by: garfo on January 30, 2015, 01:47:29 PM
No, I haven't connected those pins to ground. What is the procedure?
I've also tried another IC and the same happened.
Post by: garfo on January 30, 2015, 01:49:19 PM
Since Pin 3 is already connected to ground, shoud I just jumper 3 with 4!?
Post by: sturgeo on January 30, 2015, 01:50:38 PM
Yes, that should fix it
Post by: garfo on January 30, 2015, 03:27:33 PM
By the way, on the sea urchin schemattic, the pt2399 pin configuration(numbers) is different. Pins 3 and 4 on the schemattic are 7 and 8 on the IC datasheet pinout. How do I follow this?
Post by: gtr2 on January 30, 2015, 03:33:51 PM
The schematic PT2399 is the same.  The pins are just relocated on the schematic PT2399 for ease of making the schematic, its not the pinout.
Pins are pins...the numbering doesn't change with IC's.  Just connect pins 3 and 4 as per the data sheet with a small old resistor lead trimming.
Post by: garfo on January 30, 2015, 03:36:09 PM
Yes, after a breaf analysis, I got it. Will try to do it. Thank You all, You are legends.
Post by: copachino on January 30, 2015, 03:38:45 PM
Quote from: midwayfair on January 30, 2015, 01:46:44 PM
It's this.
i have seen this prolem on my zero point microII, but as my pt2399 were from tayda,i thought i was a bad IC, but zero point the DGND(pin4) its not connected with AGND(pin3), should the same fix work??
Post by: gtr2 on January 30, 2015, 03:52:51 PM
Quote from: copachino on January 30, 2015, 03:38:45 PM
It's this.
Yes, the same fix will work if you are having a problem with your pt2399 locking up.
Josh
Post by: copachino on January 30, 2015, 03:57:46 PM
Quote from: gtr2 on January 30, 2015, 03:52:51 PM
It's this.
Josh
interesting, i have never read about the locking up, but when debugging my first thought was bad grounding, after many time i pulled out, and use back to my cavedweller, i had to unplug and plug the pedal many times to get delay... i will try this fix tomorrow
Post by: garfo on January 30, 2015, 10:22:58 PM
Quote from: copachino on January 30, 2015, 03:57:46 PM
That's the way I've been dealing with mine, untill now ;)
It's this.
Josh
