Projects => Build Reports => Topic started by: Luke51411 on March 06, 2015, 03:02:58 AM
Title: Test setup upgrade!
Post by: Luke51411 on March 06, 2015, 03:02:58 AM
Ok so it's still not much... But it has bypass and on board power jack now,!
It was in the same house before but it just had jacks with wires for in, out, ground. I used to Hooke the power jack right up to the breadboard. Yup I'm moving up! Now I can compare to clean tone, adjust for unity gain, etc
(http://i1101.photobucket.com/albums/g429/Mandoluke/025724f33129e3d5712b0776b625f140_zpsdd0a40f0.jpg)
Title: Re: Test setup upgrade!
Post by: Hogharry on March 06, 2015, 09:18:54 AM
Nice upgrade! :D I'm planning a stomp upgrade for mine.
Post by: Luke51411 on March 06, 2015, 02:46:36 PM
Quote from: Hogharry on March 06, 2015, 09:18:54 AM
Yeah its worth it. The more I think about it the more I realize how much time it will save. It will give me an idea if something needs to be fixed that is causing switch popping and comparing to clean tone will be helpful. Now I need to build one with a built in audio probe for when things don't work quite right.
Post by: Hogharry on March 06, 2015, 11:10:10 PM
I'd been thinking about the probe idea,as,well. You don't need to build anything different, just use your test set up but connect the probe to the place that you would normally connect the board output.  8)
Post by: FloorIt on March 09, 2015, 05:07:57 PM
Can you describe what this does?
Post by: Luke51411 on March 09, 2015, 05:12:45 PM
Quote from: FloorIt on March 09, 2015, 05:07:57 PM
Sure. A very basic description is it allows me to use unboxed pcbs without their own jacks, switch, etc to be used as if they were boxed. The wires go to the breadboard. I color code the wires so Green goes to the input of the circuit, Yellow goes to the output of the circuit, red goes to the circuit power and black goes to the circuit ground. It is very useful for finding out if a pedal work and then testing it out to see if you like it. Now that I've included the stomp it allows comparison to your clean signal. It is a useful tool, most people in the hobby for long have a test setup that performs a similar function.
Post by: kgull on March 09, 2015, 05:25:25 PM
Found one of these cheap at a closing ratshack and put it on mine. Don't even need a breadboard!
(http://demandware.edgesuite.net/sits_pod26/dw/image/v2/AASR_PRD/on/demandware.static/Sites-radioshack-Site/Sites-master-catalog/default/v1425909628222/images/02740658_00.jpg?sw=350&sh=350&sm=fit)
