Ive never been a big fuzz user, but recently built an Ultrastoner (awesome circuit, btw), and I want it on my board. The problem is my usual tone uses boosts (SHO) and 18v overdrives (Kingslayer, RAH) and they put out a hot signal. Even at the front of the chainwher it sounds best, I need a way to get it up to the same level as my overdrive tone so I dont have to turn up my amp when I want to use the fuzz. Thats just not an option live. Since boosts dont sound right before or after in the chain, how can I fix this?
Still have to build my US board from Rej, but I've done a ?Lady, and also a Ultrastoner in my multi build. No problems getting unity volume with my builds (if anything, they get too damn loud sometimes.)
The canonical place to put fuzz in the chain is at the start.
Or in your Meatball's FX Loop ;) 8)
Impressive, possibly the first time I've heard of the US lacking in gain.
If it's a Mk2, the simplest way is to use the LED clippers. There'll be a marked increase in vol with those.
If you use linear for volume, which works best in my experience for Muffs, unity gain should be at noon. What experience has also taught me is that when a Muff does not have enough gain there's usually a problem in the circuit, as I have not met many dirtboxes that can outgain a Muff. Certainly not any OD, which usually sounds puny next to a Muff. The only dirtbox that comes to mind is the Crunchbox.
Check your caps. Also, a kingslayer into a muff is sweet
Juan's suggestion of using LED clipping diodes is a quick and easy way to get more volume. I prefer LED clippers in my Muff builds.
I'm not so sure that capacitor selection will have a dramatic effect on output volume (other than altering bass/treble frequencies depending on location).
Most Muff builds will always have at bare minimum a bit of boost on the output volume available.
Have you checked the US pedal in isolation just with the amp to check it can go above unity volume?
You can increase the output boost level of the Muff circuit by changing the resistors in the final amplifier stage. These are R22 and R23 in the Mudbunny schematic. You also need to alter the bias resisters if you go very far from the values that are currently there for R22 and R23. The various other Muff circuits can give you some hints as to what will work. You could actually push for more boost than even any of the normal circuits have if you want to. You could move to 18V and really put some gain out of the final stage.
The Muff's do usually have quite a bit of gain though. I've got one where I use Ge diodes and it still has well past unity on the output and I use pretty hot pickups. So, check that everything is working as it should be before you look into altering the circuit.
The problem is not with gain or volume in the US. It is with matching its level with the high output level of my other pedals. I run into a SHO, then into a Kingslayer, which gives a high combined output signal (and sounds awesome). The US sounds best (to me) alone, but can't get close to the output of those two pedals combined. So, I'm wondering how to get the level of the US up to match the others, not to unity with my guitar signal. I use either my SHO/KS tone, or my US tone, but need the US tone boosted. The problem there is the US doesn't sound as good (to me) with a boost.
Does that make sense?
Is there a super transparent boost that might work with it?
SHO after US, use it for boost.
Thanks, I'll try it.
Juan, Alan, Rej, Cleg, and everyone else, awesome pedal btw!
Quote from: AntKnee on March 12, 2015, 05:30:06 PM
Try Madbean Bacon Bits. It's an opamp booster with +/-9V supply rails. Will be transparent ,clean, and give oodles of volume.
Plus you'll be putting a few $ in our kind hosts pocket ;)
Quote from: raulduke on March 12, 2015, 05:49:17 PM
Our host gets plenty of my $, believe me!
I'll try the bacon bits out. I may also just build another vero SHO to put at the end of my chain, too. I tried a Fatpants after the US, but didn't like it.
I think I feel a dual box coming on...
Try modding the output amplifier resisters. The gain of the amp is pretty much given by -R_c/R_e. If you look at the charts with various Muff parts list, you'll see that there are other variants that have higher output gain. You can use one of these as a starting point. If that still doesn't get you enough volume, you can change the output to an even higher gain. The bias resistors on the base may also need to be changed. Look at the matching set in the parts list for the one you use.
You could mod the thing to go off of 18V too. The final stage could then be made to have a ton of gain with no added distortion.
Quote from: RobA on March 12, 2015, 06:28:15 PM
I would be interested in doing this, but wouldn't know how to go about doing it.
I'll try putting my SHO after it and see what happens. If that works out, it will be simpler (not easier) for to just throw a SHO into a 1590BB with a Stoner.
Anyone used a Beauty Boost? I have one of those populated, but unused. I don't know how it sounds yet.
Quote from: AntKnee on March 12, 2015, 07:44:11 PM
It wouldn't take much to do it. If the caps you have in there are rated at 25V or more, they'll all be OK. If you had any 16V caps in, especially in the power section, they'd need to be changed.
If the circuit you are using has a power filtering resistor in it, you need to make sure that it can handle the power across it, but the current draw is small enough that it shouldn't be a problem with any of the circuits I've seen.
The first gain stage is probably going to be a bit cleaner, but that shouldn't really be a problem. The middle two clipping stages aren't going to need any changes really since everything there is pretty much limited by the diodes. If you've got a mod in place to toggle out any of the diode sets, then it could get cleaner and louder here because the clipping from the transistor will be reduced.
The only real modification needed is in the output amplifier, and even here it'll work without any mods. But, you would want to mod this section because the whole point would be to allow this section to have more clean gain. The tone control section attenuates the volume quite a bit, so the final amplifier is where you get most of the volume. At 18V, you can get a bunch of gain out of this amplifier. The only changes needed are in the resistor values. What you want to use depends on how much gain you need. It isn't hard to figure out though.
I just put 18V on a couple of my Big Muff builds. It works fine. One of them has settings that can remove both sets of clipping diodes. This gets loud at 18V! I've been wanting to test a tone control mod, so I might have a go at putting this on the breadboard and take a look at what happens with the 18V mod while I'm at it. I'll let you know if I get a chance to do it any time soon.
Quote from: RobA on March 12, 2015, 10:05:39 PM
I'd like about the same amount of gain available from my Kingslayer. So, its basically just a matter of raising the values of the resistors in the output section and squeezing a Road Rage in there?
That's basically the idea, although you can alter the gain of the amplifier stage by either raising the collector resistor or lowering the emitter resistor or both. You may need to alter the bias resistors depending on what happens with the other two resistors. You may not need to move to 18V at all. It depends on how much extra gain you need.
I don't have a Kingslayer or an Ultrastoner build of a Big Muff, so I can't compare directly. I can make a pretty good guess of where the volume level of the Ultrastoner should be based on the muffs I do have and comparing the output stage values.
Maybe we can figure out how much more gain you need from the final amplifier stage this way -- where do you set the volume level of the Kingslayer normally and how far do you have to turn it down to bring it down to the level of the Ultrastoner?
The Musket Fuzz puts a LPB booster before a Big Muff. Maybe that's what you're looking for?
Quote from: Muadzin on March 13, 2015, 05:33:26 PM
Part of the problem is that any boost in front of the Ultrastoner in the chain gets compressed down such that it does no good.
I am going to try the US into my SHO tonight and if it works I will do a dual box build with the SHO. I have a couple extra Ultrastoners anyway.
I finally got a chance to put this on the breadboard and test it out. I had simulated it in LTSpice to do some quick testing and get an idea of how far it could be pushed first, and the bread board results are pretty consistent with the simulation.
The first thing to note is that if you are using 1n4148 type diodes for the clippers, then whatever version of the Big Muff circuit you are using is close to irrelevant for this test because the clippers alone pretty much set the level going into the final amplifier stage. If you were to do different diodes, then you could end up overdriving the output stage depending on what you did use. Given that, I put what's close to a Violet Ram's Head version on the breadboard. I had a slightly modded first gain stage but not by a whole lot. I used BC550C transistors for this test. With the VRH values in the final amplifier (resistors of 100k, 390k, 2.7k, and 10k) at 9V I get about a 2V peak-to-peak swing on the output of the amplifier (before the volume pot). If I move that to 18V with the same values for the resistors, it'll move up to about 2.2V peak-to-peak on the output swing. There is a slight change in tone probably from increased headroom in the initial amplifier stage.
I then changed the output amplifier to use 68k, 680k, 2.2k, and 30k resistors. This should be a big increase in the output level. At 9V, the output level is about a 4V peak-to-peak swing with maybe a touch of distortion added in the output amplifier. With the same resistors at 18V, it gets a bit more than a 6V peak-to-peak swing on the output with no added distortion in the output wave shape.
If you were to move the collector resistor down to 27k from the 30k, you could probably do it at 9V without much change in the tone of the pedal and still get a good boost in volume. If that's not enough, pushing it to 18V with the 30k and the 2.2k does give a pretty good increase in output level
Sorry for the late reply.
Thanks for the research! I'll give it a try.
