Projects => General Questions => Topic started by: FloorIt on April 13, 2015, 04:55:05 PM
Title: Knobs for Kingslayer/Cenataur
Post by: FloorIt on April 13, 2015, 04:55:05 PM
I am building a Kingslayer which will go into a 1590B enclosure.  The standard oxblood pointer knobs (Davies 1400) like what SmallBear has are too large.  Does anyone make a smaller oxblood pointer knob?  If not, what good alternatives are there?  I plan to use a polished aluminum enclosure and want a look that is similar to the Klon.  Does anyone make oxblood/maroon knobs in other styles?
Title: Re: Knobs for Kingslayer/Cenataur
Post by: jtaormina on April 14, 2015, 02:44:35 AM
It's kind of oxblood (maybe a little more brown)
http://www.mammothelectronics.com/4SK1400BR-p/700-1505.htm
Post by: FloorIt on April 14, 2015, 11:31:30 PM
Quote from: jtaormina on April 14, 2015, 02:44:35 AM
Any idea what size these are?  Are all 1400 knobs >1 inch?
Post by: Stomptown on April 14, 2015, 11:58:48 PM
Quote from: FloorIt on April 14, 2015, 11:31:30 PM
".25" shaft with set screw 17 x 10.8mm .67" diameter at skirt"
Post by: mremic01 on April 19, 2015, 10:06:47 PM
Quote from: FloorIt on April 13, 2015, 04:55:05 PM
I'm surprised the 1400s are too large for your build. They're much smaller than what's on the real Klon (1470s). I use the 1470s on full sized klones and the 1400s on 1590BBs or smaller.
Post by: FloorIt on May 06, 2015, 11:30:25 AM
Quote from: mremic01 on April 19, 2015, 10:06:47 PM
Sorry, the Smallbearelectronics oxblood knobs are 1470s not 1400's.  I have not been able to find oxblood 1400's.
Post by: mremic01 on May 06, 2015, 05:14:32 PM
Quote from: FloorIt on May 06, 2015, 11:30:25 AM
These ones: http://smallbear-electronics.mybigcommerce.com/oxblood-pointer-white-index-large/
Post by: flanagan0718 on May 06, 2015, 07:42:20 PM
I like the ones from BLMS.
here: http://www.bitcheslovemyswitches.com/#!/Davies-1400-Clone-Knobs-1-4-Shaft/c/5226016/offset=0&sort=normal (http://www.bitcheslovemyswitches.com/#!/Davies-1400-Clone-Knobs-1-4-Shaft/c/5226016/offset=0&sort=normal)
Post by: davent on May 06, 2015, 08:36:06 PM
I've got some chicken heads from AES but they'd be too big.
Why not paint with artists acrylics, colour possibilties are infinite. Golden even has a colour calculator that shows you what colours and proportions to mix together to reach your target colour.
