Projects => General Questions => Topic started by: stellablue on February 03, 2016, 04:27:10 PM
Title: Mudbunny wiring- use of 3pdt switch board
Post by: stellablue on February 03, 2016, 04:27:10 PM
Hello, it looks like my Mudbunny board is from an erlier version. I would love to use a 3pdt switch board to wire this up. The pads on the board say sw-in-gnd-out. On the left side of the board is the 9v and gnd. Where does the wire from the SW pad go? Transistors are Russian KT3102 which is why they are backwards. I also used all mylar and Russian kd521 diodes to give it some original character.(http://img.photobucket.com/albums/v304/kstraker/008_zpsletpsx6g.jpg)
Title: Re: Mudbunny wiring- use of 3pdt switch board
Post by: stellablue on February 03, 2016, 04:45:16 PM
I see in this picture from another thread, the SW pad is left empty. I'll give that a go and see if this sucker comes to life.
(http://www.madbeanpedals.com/forum/index.php?action=dlattach;topic=18046.0;attach=10352;image)
Post by: Jebus on February 03, 2016, 04:52:21 PM
Hey!
The SW is for switching the LED and it is supposed to connect to the switched ground on the 3PDT switch. You have couple different options on the wiring: if your 3PDT board has place for LED you can use that instead of the one in the PCB or you can mount the LED to the Mudbunny PCB and run a wire from SW to the switching ground of your 3PDT board. :)
Post by: stellablue on February 03, 2016, 04:55:42 PM
So if I mount the led on the 3pdt switch board, I can leave the SW pad empty, correct? Thanks for the help.
Post by: Jebus on February 03, 2016, 05:36:08 PM
Quote from: stellablue on February 03, 2016, 04:55:42 PM
Yes, that is correct. You can also omit R25 (but don't need to since you probably have already soldered it in). Its the current limiting resistor for the LED.
