General => Open Discussion => Topic started by: sturgeo on February 07, 2016, 08:52:22 PM
Title: Buffer Bypass Switch
Post by: sturgeo on February 07, 2016, 08:52:22 PM
I'm working on a new utility pedal and would like to make the primary buffer removable from the circuit when necessary.
I'd also like an always on tuner out, I've made a quick diagram to show my intended solution.
Will bufffering the tuner out as shown negate the effect of having a parallel tuner out when the primary buffer is bypassed?
(http://i1374.photobucket.com/albums/ag418/jsturgess/Screen%20Shot%202016-02-07%20at%2020.34.55_zpstqcyeiln.png)
P.S. ignore the opamp pins etc, purely to show signal routing.
Title: Re: Buffer Bypass Switch
Post by: GrindCustoms on February 07, 2016, 08:55:03 PM
We've also worked on a buffered bypass similar to what you're attempting, we had one issue with it, bypass would work and all, but i had a constant humm when bypassing the effect, will have to check back into it.
This is what we did:
Post by: kgull on February 07, 2016, 08:57:41 PM
Quote from: sturgeo on February 07, 2016, 08:52:22 PM
Nope. I'd also lose SW1_A. Op amps have a REALLY high input impedance and won't have any effect on the signal. If you leave the input hanging like that you may get oscillation.
Post by: kgull on February 07, 2016, 09:06:01 PM
Quote from: GrindCustoms on February 07, 2016, 08:55:03 PM
Might be the circuit itself oscillating. See if the hum clears up by tying the circuit input to ground when bypassed.
Post by: m-Kresol on February 07, 2016, 09:12:47 PM
I might be utterly wrong here, but I thought that an opamp buffer always has negative input and output connected?
I also would not use the inverting (-) input of the opamp for the signal as this might have affect some effects in a bad way, iirc.
Post by: sturgeo on February 08, 2016, 09:29:23 AM
Quote from: m-Kresol on February 07, 2016, 09:12:47 PM
Sorry, as mentioned below the picture the pinouts are incorrect, it's only to show the basic signal flow.
Also, i forgot to label it but SW1_A pin 1 would be connected to ground.
Post by: sturgeo on February 09, 2016, 11:36:37 AM
As completely bypassing the buffer appears to cause issues with the tuner permanently connected i might change the output impedance of the buffer using a dpdt instead, selecting between the standard 560r resistor (K based buffer) and a higher value between 1-10k.
In my head this is the best way to make it play nice with fuzz and some vibe pedals, hopefully it shouldn't attenuate the volume too much  :-\
To the breadboard batman!
