I shoe horned this one in just because I was too lazy to buy the tall version of the box. I'm going thru a second wave of sparkle obsession and it bit me because I didn't shoot enough clear coat before the decals to smooth it out and it ate a few areas of the decal. If it wasn't for my stash I'd have redone it but as long as I can read the labels...
Stock except for the external Filter and Rez knobs. I'm glad I put them on the outside as I fiddle with them a lot. Lumberg jacks to the rescue (I love these things). This one fired up on the first go around. I had to grind the lip off the inside of the bottom cover above the jacks but other than that just a bit of careful measuring.
I honestly have no idea what I'll use this for, but it's a fascinating effect and I've been monkeying with it for some time now.
(http://www.gordomusic.com/Madbean/DD02.jpg)
(http://www.gordomusic.com/Madbean/DD03.jpg)
(http://www.gordomusic.com/Madbean/DD04.jpg)
surprising! It was perfect. I do not know how you did it to fit on such a small box
it really is perfect
Nicely done!
You are a frikkin maniac. Good jorb!
Crazy!
That's crazy! Nice job.
Awesome! I really like the look of the pedal and the decal. :)
I knew it was possible! That is so awesome. I am just not a fan of the tall enclosures and really wanted to make this happen also. Great job!
It is one hell of a clean build. Inside and out.
WOW!!! youre the crazy lazyman, good job
Great work!
Wow. That is tight. Good job. I like the different knob choices as well.
I agree, you're part genius part crazy man. Great job on squeezing everything in there!
That's pretty spectacular! And the paint job is absolutely amazing!
Sent from my SM-G928F using Tapatalk
incredible thingy of awesome sauce.
Super nice wiring job!
That's what I call a clean build.
Man I love those knobbles pots. I use them a lot.
Everything about this is so impressive.
Dude that's impressive!
(Blush), thanks guys. I closed it up last night by snapping off the areas of the lip on the lid above the in/out jacks. The metal used in the current wave of enclosures is such garbage that it made it a breeze to just use a pair of pliers and snap off the areas and minor clean up with a file. Hit the edges with a bit of paint to match the sides and it's done.
Then sat at the bench and played it for an hour. It's a bit addictive.
8)
That is cool. Nice work fitting that all in the box.
did you use the aluminum shaft 9mm pots for the term and wah?
I did with mine. No problem at all. With mine, one of the rotaries (I think I used a 1P4T for the 2P4T) was a little lower than the other so i fixed them to the enclosure and then soldered them in to get it level
Yupp, they fit quite nicely.
Kind of like building a ship in a bottle...
Well done!
Quote from: gordo on February 15, 2016, 06:21:31 PM
Lol. Anyone who builds something like that is far from lazy!
A very inspiring meticulous build, man.
Thanks again guys, but no....laziness is the mother of invention. This coming from a guy that hates 1590A builds but appreciates the real estate savings on my board.
