Projects => General Questions => Topic started by: brucer on February 27, 2016, 01:37:58 AM
Title: Recommendations for a very small clean boost?
Post by: brucer on February 27, 2016, 01:37:58 AM
Hi All.
I've got a couple of pedal builds that don't get much above bypass unity with effect at max volume.   One is a BYOC Tonebender (my 1st build ever!) and an Aion Canned Yam (NE-1 EQ).
I'm thinking that I might be able to fix this volume issue by installing a small, clean boost circuit between the effect "Out" and the switch.  Am I missing anything obvious?  I mean, this should give me more volume to work with when the effect is on, right?
Also, if this would work, can anyone give me a recommendation for a very small, clean (and preferably very quiet and tone-neutral) clean boost that I could fit into a 1590B with these circuits?  The one I'm considering is this: http://tagboardeffects.blogspot.ca/2013/04/escobedo-duende-jfet-jhs-minibomb.html (http://tagboardeffects.blogspot.ca/2013/04/escobedo-duende-jfet-jhs-minibomb.html)
Any advice would be appreciated.
Thanks, Bruce.
Title: Re: Recommendations for a very small clean boost?
Post by: vizcities on February 27, 2016, 01:51:23 AM
The Tagboard Effects Super Hard On clone is clean and ludicrously easy/small.
Post by: Willybomb on February 27, 2016, 08:34:16 AM
+1 to that, or tagboards version of the Crackle Not Ok, which is much the same thing but without crackle. That's my go to boost.
Surprised your Ne-1 is quiet, I built one on vero from paulinthelabs layout without issue. Love that for bass.
Post by: mcasemo on February 27, 2016, 05:22:11 PM
EHX LPB-1 is often used for this, super simple circuit.  This schematic shows it used to boost a Shin-EI companion fuzz
http://www.generalguitargadgets.com/effects-projects/fuzz-tones/shin-ei-companion-fuzz/ (http://www.generalguitargadgets.com/effects-projects/fuzz-tones/shin-ei-companion-fuzz/)
Post by: midwayfair on February 27, 2016, 05:24:31 PM
You don't need a boost to increase the volume of the TB. Find the schematic. There will be a voltage divider on the last transistor's output. You just need to change one maybe two resistors.
Post by: daleykd on February 28, 2016, 12:40:36 AM
The AMZ MOSFET Booster is probably one of the cleanest volume boosts.
