I looked in the buying guide for the 1590G projects but didn't see where the dual gang pot for the Ping could be found. I checked a few of the usual spots (smallbear, PPP, mammoth, tayda) but I don't see any dual gang 9mm pots.
I know Brian wasn't initially going to release the Ping so maybe he left the dual pot out of the guide?......
Anybody have a good source for a 9mm dual 100kB?
There's a link in the Ping build doc for a pot from smallbear but the link takes me to this:
Not Found
The page you were looking for appears to have been moved, deleted or does not exist.
This is most likely due to:
An outdated link on another site
A typo in the address / URL
Found this one at smallbear but it's not right angle........
http://smallbear-electronics.mybigcommerce.com/alpha-dual-gang-9mm-pc-mount/
That's the correct pot. Looks like there is some extra text in the link in the doc which is making it not go to the right location. I'll fix that.
The pot I linked isn't a right angle pot......
Wouldn't the shaft of the pot be parallel to the PCB?
Nevermind, I'm an idiot.
I see (scrolling all the way down on the build doc) that you soldered jumper wires from the pot to the board.
(facepalm)
I've actually read through the build doc already. Just forgot about that little detail and was ordering parts yesterday.....
Now I need to place another order for a single pot!
