I just wrapped up my first 1590A build last night, and I'm hooked! It's a Stomptown Electronics Baby Screamer. I used the values for the Keeley mod plus to tweak this little guy. I love it!
I still suck at enclosure finishes, so this little guy is sitting in a unmarked enclosure. I want to start doing more finishes on enclosures, but I have the hardest time coming up with ideas.
Anyway, here are the obligatory pics:
(http://uploads.tapatalk-cdn.com/20160326/356bdf43fbc3abd125265ad7eaab0130.jpg)(http://uploads.tapatalk-cdn.com/20160326/37c96fca250deedf10c41ad80c06bb1e.jpg)
Andy
Tidy! Aren't those Lumberg jacks the best? If they weren't so (relatively) expensive, I'd use them on everything.
Thanks! This is my first time using them. I did have a problem where the tip connection wasn't bent correctly on one of them and the Jack would go under instead of over. A little retensioning and all was well.
Oh, and I did use a BB OPA2134 for the op amp as well. I forgot to list that above.
Great job!!
Nice, love 1590s. And nothing wrong with a plain enclosure, though it is fun to develop a style that you dig too.
Nice job. For the outside, don't overthink it, I usually use the first thing I see that looks cool / funny / neat and just use that.
Nicely done! 8)
Thanks guys! Since I build for myself I typically go function over form. I have a ton of baby boards built up right now. This was just the first of many wee ones. I do have to say that the board mounted pots and led made this one a snap to box up. I'll know I really cut my teeth on 1590A's when I get to the rest that are all off board pots and LEDs.
Thanks,
Andy
I was asked in a PM what changes I made to mod this build to the keeley specs. Here are the values that I changed:
R3 - 510k
R6 - 2k4
R13 - 510k
C3 - 51pF
C4 - 100n
C6 - 180n
The part numbers listed are the ones from the Stomptown build doc. I did notice a disconnect between the schematic part numbers and the BOM in the build doc, so the numbers listed are from the BOM, not the schematic.
I really like the way this mod sounds. It adds a level of ballsiness to the circuit, while still being clear and articulate, that I've not heard before.
Thanks,
Andy
for a first 1590a you really killed it
Thanks! I've become infatuated with all things mini now. I have a pickdropper Trem waiting to be wired up and a bunch more I just got the last bit of parts in for. Pretty soon my whole board will be tiny.
Quote from: v00d00blues79 on April 07, 2016, 03:35:20 PM
Thanks for the heads up! I'll take a look and get the schematic updated.
You're most welcome. I meant to shoot you a message about it when I found it, but the little bugger was too much fun to play and I forgot.
