Projects => How Do I? Beginner's Paradise. => Topic started by: K3yPr0gg3r on May 01, 2016, 11:48:22 PM
Title: Re: Resistor Size
Post by: K3yPr0gg3r on May 01, 2016, 11:48:22 PM
Hi,
I downloaded a Resistor Color Code guide to assist me with identifing the various resistors that I need while populating a PCB. I've noticed that in some build docs. I need an R value resistor, (i.e. 100R). I've checked the guide, and the colors of an R resistor and an ohm resistor are the same. So am I correct in assuming that a 150R resistor is the same as a 150 ohm resistor?
Thank you
Post by: jimilee on May 01, 2016, 11:54:44 PM
Jes!
Post by: davent on May 02, 2016, 12:05:49 AM
The capital 'R' is an easy keyboard entry that sorta approximates the look of the ohm/omega sign, Ω, at least that's what i always figured.
Post by: BrianS on May 02, 2016, 12:16:13 AM
One thing that I learned from a member on this forum was to check every resistor with my multi meter before using it in a build. Is it monotonous, yes (especially when you have a large resistor count), but it will keep you from potentially making a mistake. My rate of success on first time fire ups went up a lot after I started doing this.  I use a piece of styrofoam and line up the resistors according to the build doc and start measuring them.  It's pretty much fool proof if you go slow when you start putting them on the board.
Post by: HamSandwich on May 02, 2016, 12:35:55 AM
Quote from: davent on May 02, 2016, 12:05:49 AM
I always thought R was just 'resistance', but your reasoning also makes sense.
Post by: galaxiex on May 02, 2016, 01:07:29 AM
Not to be too nit-picky here....  :)
.... but resistor *size* could be mistaken as the physical size of the part, eg: 1/4 watt 1/2 watt etc...
What you are talking about is the resistor *value* 150 ohm, 120K ohm etc...
I'm not the parts police,  ;) ... but I think it's good to get in the habit of having the terminology correct.
And to also answer your question as above, yes the capital R means ohms, so also yes, your 150R means 150 ohms.
The R is included to avoid a mistake such as using a 150K instead.
Post by: AwesomeTyler on May 09, 2016, 04:44:59 PM
I've got a question relevant(ish) to this:
As a noob that just bought a mountain of boards, I'd prefer to just buy everything I need in bulk order and get a real part organizer going. It's killing me though, I don't wanna order a ton of parts and get the wrong ones. Can 100k resistors be misconstrued in anyway? Mouser only filters by ohms, and I don't wanna accidentally order 200 100 milli or mega or kilo anything just to have a ton of parts I don't need. Is there a difference between 100k and 100K or any other variation I need to look out for or would each variation stand for a 100,000 ohm resistor? I know it's a dumb question, but we're talking about a ton of components here lol.
Thanks guys,
Tyler
Post by: K3yPr0gg3r on May 09, 2016, 05:12:03 PM
Tyler,
I'm going thru Mammoth for my resistors...the blue ones, (metal film), unless the build calls for the tan, (carbon comp). I've run into that on only one of my builds. Mouser can get confusing at times being new to building myself. Caps. are my biggest stumbling block. Once I have the correct value I just "bookmark" that page. I must have 30 to 40 pages marked in my pedal folder. You can also find components on Newark, Tayda Electronics (diodes, IC's and transistors), and at diyguitarpedals.com. The box caps are in nanofarads so NO conversion, and he has some hard to find components as well! Just FYI, those will be coming from Australia, but he gets stuff right out.
Hope this helps
Post by: BrianS on May 09, 2016, 08:13:44 PM
I would go to Tayda for your resistors and film box caps for just starting. It could be hit and miss with their ICs (I've gotten a couple of bad ones) and electrolytic caps.  Their resistors and box caps register just as good as the ones from Mouser (and someone will comment that the quality isn't as good and that could be very true) but for starting out it is by far the easiest and least expensive place to buy stuff. Sockets and potentiometers are good also. Once you get a handle on everything and what you want to stock up on then buying from Mouser, Allied, Newark, Arrow, etc....... Is the way to go when you can buy in bulk and get good pricing. One thing you have to watch out for is shipping costs. They will eat your rear end up.  Forgetting a part (and everyone does) can cost a lot or add time (waiting to order for another project) to building your pedal. If you get hooked on this (likelihood in the high 90 percentile) organization (spreadsheet) is extremely helpful.  Ordering from Mouser is pretty daunting for sure. But you will get the hang of it.
And Tyler the resistance filter at Mouser goes from ohms (which would be a 100r resistor on a build doc) to Kohms (100k resistor) to Mohms (1m resistor), etc... Hope this explains that for you.
Post by: midwayfair on May 09, 2016, 08:24:02 PM
Typical size of 1/4W resistors is 7.68mm. But most of the time you can assume that they're that size. Manufacturers don't want to make their parts incompatible to existing parts libraries and PCBs. They want to make things easy on you.
Post by: AwesomeTyler on May 09, 2016, 08:31:30 PM
Thanks so much to the three of you. Very useful info.
Anything else I might wanna look out for whilst ordering a fully stocked organizers worth of components?
I'm here neatly not too ashamed to post links to what I'm about to buy before making the purchases. Or at least the cart.
Any reason I should go with high end stuff from Michael Percy or partsxconnection?
Post by: AwesomeTyler on May 09, 2016, 10:24:12 PM
I'm still very much looking into whether or not it's worth it to buy 'high-end' or 'audiophile' quality components for some pedals and which components would be worth having or even make any noticeable difference.
In-particular, partsxconnection has some resistors 'on sale' that have a were magnetic draw than typical resistors. Not sure if that's sales hype or not, but having components with a low noise-floor/less electro-magnetic field seems worthwhile.
There's also caps that go into the $50 a piece area (wtf?!). Not sure what using an oil filled cap would do to a pedal to affect tone..but at those prices, I'm not sure I even wanna know.
Post by: davent on May 09, 2016, 10:49:37 PM
I would think the coveted amps and pedals of yore were made with the very cheapest parts available to the makers at the time of manufacture. Do we want cleaner dirt or dirtier dirt?
Post by: AwesomeTyler on May 10, 2016, 12:11:03 AM
Quote from: davent on May 09, 2016, 10:49:37 PM
Well, that's assuming we want dirt at all in this case. Obviously dirty is a slightly different story, albeit not entirely. I still hate that I can't gig with a Big Muff in venues larger than a small dive bar due to the sheer volume of the noise on a dimed amp.
I'm looking more into effects that perform a specific duty and need to perform as 'dead-on' as possible (ie. Delays, filters, mod). If shinier components will help it do it's job as expected time and time again or lower unwanted ambient noise, then shinier components it will get (within reason). If we're talking about to small of a difference for it to ever make a noticeable difference, I'll stick with building $30 a pedal.
-Tyler
Post by: BrianS on May 10, 2016, 04:55:40 AM
What Dave said is probably very true.
I was at a very well know commercial pedal makers shop last year and was talking with one of the employees and asked where they got there 3pdt stomp switches. His reply, the cheapest we can find.  I was a little in awe because the b stock pedal I purchased cost $165. If you are looking to fine tune your parts I believe the audio path is where most put the high end caps and parts. I'm not an electronics expert but a 1 cent 10k metal resistor that measures 10k on your multi meter should be just as good as a 50 cent one. It may not have the longevity of the 50 cent one but In my case that resistor will probably last for as long as I need it to. Also take into consideration the amount of power going through the pedal. In most cases it's not very much. Not a tremendous amount of push on the components. Again, and I'm not being a smart a--, it's ultimately your money and if it puts you in the comfort zone then go for it.
Post by: Willybomb on May 10, 2016, 06:03:10 AM
I just use whatever I've got lying around normally.  I've got stacks of builds that are a mix of carbon, metal film, greencap, box, ceramic, those little blue monolithics...
Post by: Addy Bart on May 10, 2016, 10:17:39 AM
Quote from: BrianS on May 02, 2016, 12:16:13 AM
I've just begun testing them beforehand, however as I don't buy in bulk I'm pretty much using whatever ordered. A value has to be way off for me to ditch it, cheapskate that I am ;D
I'm curious though where others draw the line, and if there are certain parts of a circuit where one should only use resistors with accurate values?
Post by: Stomptown on May 10, 2016, 01:37:05 PM
Quote from: Addy Bart on May 10, 2016, 10:17:39 AM
I think most people are just checking the value rather than tolerance.  Can't trust vendors or color bands alone.  Of course it does give you the opportunity to check tolerance but I doubt there are many folks sitting there with a calculator making sure every metal film is within 1%.
Post by: BrianS on May 10, 2016, 03:24:39 PM
And what Jon just said is what I guess I am getting at. I had some resistors (and this has only happened one time) that were colored coded correct but were not even close to being in tolerance (i think they were suppose to be 47k and were measuring over 56k). There were several on the build doc. Would the pedal have worked with them in there? I don't know but it would have been a complete fiasco trying to trouble shoot the board if it didn't. Now I believe I have had some builds that the doc recommended that certain resistors be spot on as far as tolerance but those have been very very few.
I also purchased a capacitor meter after building about 30 pedals and measure each one of those also.  It saved me on one bad electrolytic cap. But I am not really measuring for tolerance on anything, just making sure the electrols are good and the box caps are true to their number.  Just added comfort for myself and another part taken out of the equation if the board doesn't work.
Post by: wgc on May 10, 2016, 04:46:50 PM
Its all relative.  You usually can't sub a 100k resistor where a 100R is called out.  But a 110R or 120R will probably work fine. Or 80 or 90R.  My personal general rule of thumb is 5-10%, and in many cases you can get ohms law to work for you by combining two resistors to get the value you actually need.
That said, experimentation can be fun and many of the amp mods and circuits we have today would probably not exist otherwise.  Make notes and try things out.
