Hi guys, it's been a while since I posted a build report..
I have here another N.Fish which has been populated for long time.. I couldn't find on/on/on switch, so Brian send me one for free and finally it is finished! Yaaaaay! :D This is gift for a good friend of mine who is a bass player. Again I must say BIG thanks to Brian!
(http://i1327.photobucket.com/albums/u661/Brejna/fis_zpscfmibnqq.jpg) (http://s1327.photobucket.com/user/Brejna/media/fis_zpscfmibnqq.jpg.html)
Second one is BSIAB2 with contour pot and 18v operation with fet switching, squeezed in a 1590a enclosure. Finish is laser etched faceplate.
(http://i1327.photobucket.com/albums/u661/Brejna/br_zpse93ufmwc.jpg) (http://s1327.photobucket.com/user/Brejna/media/br_zpse93ufmwc.jpg.html)
Third one is Ego driver I got from Tremster in PIF month of 2014 and it was time box this thing... Thanks mate once again for pcb. Enclosure is etched, painted and brushed..
(http://i1327.photobucket.com/albums/u661/Brejna/ocdd_zps7cdoljjk.jpg) (http://s1327.photobucket.com/user/Brejna/media/ocdd_zps7cdoljjk.jpg.html)
And fourth one is Micro Vibe, my try on ic based univibe built in 1590a enclosure which is reverse etched and painted. There are two boards inside, one is audio part and other one lfo mostly. I added fet switching, too.
(http://i1327.photobucket.com/albums/u661/Brejna/micc_zpsqppr49vu.jpg) (http://s1327.photobucket.com/user/Brejna/media/micc_zpsqppr49vu.jpg.html)
I hope you like them..
Cheers
Brane
Daaaaammmnnnn, those are pretty.
You crazy kids and your tiny builds! Nicely done.
Awesome looking pedals Brane! I'm sure they sound as good as they look. I hope that you will make the flower vibe available ;D
Great! I would love to build the bsiab in a 1590a !
Thanks guys on kind words. I will offer rest of boards for those who are interested..
Awesome! Especially the Vibe. Man, amazingly well done.
+1 on the mini vibe, would love a chance to purchase a set of PCBs.
Great work.
Those look fabulous :-)
I'm down for a mini vibe! Looks great!
Really awesome! I would be down for a BSIAB or two.
Thanks fellas! If someone is interested I am offering some pcbs for sale http://www.madbeanpedals.com/forum/index.php?topic=23120.msg226697#new
Cheers
Brane
Where do you get those flat handled switches from?
Quote from: Timko on June 15, 2016, 07:23:03 PM
I got them from Musikding http://www.musikding.de/
Beauuuutiful builds! Very impressive work sir!
Great stuff!
Nice etches!
Thanks guys :)
Hi,
What bulb did you use on the mini-vibe? I looked in your build docs and didn't see one specified.
Andy
Quote from: v00d00blues79 on June 21, 2016, 01:29:45 PM
Hi,
Andy
Best option is to use low current bulb. I used 12v 20mA in my build.
Cheers
Brane
I'm sure it can be done using this kind of dual pot for "Speed"
http://www.banzaimusic.com/Alpha-9-PC-STE-100k-lin.html (http://www.banzaimusic.com/Alpha-9-PC-STE-100k-lin.html)
but the PCB is made for this kind, with the two legs, right:
http://www.banzaimusic.com/Alpha-9-PC-ANG-100k-lin.html (http://www.banzaimusic.com/Alpha-9-PC-ANG-100k-lin.html)
Is there a source for the correct one?
Quote from: Tremster on June 21, 2016, 03:23:07 PM
I used as you say correct one, but it seems it is out of stock :/
First one should work, but you will just have to be careful with assembling
Quote from: brejna on June 21, 2016, 03:06:20 PM
Hi,
Andy
Cheers
Brane
Would you be able to point me to where you picked yours up from? I'm not having much luck with the search and I'd hate to order the wrong one.
Andy
Quote from: v00d00blues79 on June 30, 2016, 11:38:53 PM
Hi,
Andy
Cheers
Brane
Andy
I'd bet this will work fine.
http://smallbear-electronics.mybigcommerce.com/lamp-12-volt-04-amp-bi-pin-7371/ (http://smallbear-electronics.mybigcommerce.com/lamp-12-volt-04-amp-bi-pin-7371/)
Andy
I got mine in local store and it is very small bulb. I will see what is offered in US and post link
Quote from: jtaormina on July 01, 2016, 12:35:49 AM
I think this one is too big, it won't fit inside 1590a box..
This one is possible match, I will email smallbear for it's size..
http://smallbear-electronics.mybigcommerce.com/lamp-18-volt-026-amp-bi-pin/
The size of that one is fine, I have one here and it will fit. Will the 18V pose a problem?
Quote from: dan.schumaker on July 01, 2016, 02:47:36 PM
Is this the same thing Dan? Google found a similar part number at mouser.
http://www.mouser.com/Search/m_ProductDetail.aspx?JKL-Components%2F8099%2F&qs=Xy34DXS8Eha0yYjyu6tI7Q%3D%3D (http://www.mouser.com/Search/m_ProductDetail.aspx?JKL-Components%2F8099%2F&qs=Xy34DXS8Eha0yYjyu6tI7Q%3D%3D)
I think it will be ok, SME wouldn't offer them for univibes otherwise. Did you order this one? Also I got email from Small Bear and dimensions are
Light bulb - 3 mm in diamter, 3.5 mm in height.
Body that hold bulb - 3.8 mm in diameter, 3 mm in height.
Leads - 0.5 mm in diameter, 6.3 mm in length and 2.5 mm spacing between leads.
