Projects => General Questions => Topic started by: ddavis20341 on July 06, 2016, 02:35:29 PM
Title: Karate Shop Wiring Question
Post by: ddavis20341 on July 06, 2016, 02:35:29 PM
Hey all,
First-time builder here, been admiring madbean's stuff for a while and finally decided to get my feet wet. I finished a Karate Shop build a couple of days ago, but I haven't been able to get any sound out of the pedal.  At first all I got was silence, with the pedal engaged or bypassed, and after re-soldering a wire now I just get a loud buzzing whenever the pedal is plugged in, still no guitar sound both engaged and bypassed.
I followed the wiring diagram and can't seem to see anything wrong with the switching assembly (since I'm not getting any sound at all, I understood this to be a switching problem), other than some char on the outside of a few wires. I'll post pics below, but if anyone has any idea what's wrong it would really be appreciated.
Title: Re: Karate Shop Wiring Question
Post by: madbean on July 06, 2016, 03:07:10 PM
When testing outside of an enclosure, you need to ground the sleeves of both jacks. Inside the enclosure you only need to ground one because the enclosure itself acts as a ground. That may be why you are getting nothing out.
Post by: jtaormina on July 06, 2016, 04:55:25 PM
Quote from: madbean on July 06, 2016, 03:07:10 PM
Take the ground lug of your output jack and add a wire to the food switch on either end of your tiny yellow wire.
Post by: ddavis20341 on July 08, 2016, 01:11:58 PM
Great! Added a ground outside of the enclosure and it worked, and then boxed it up and it worked like a charm. Thanks a lot for the help, I am really digging this pedal.
Cheers!
Post by: jtaormina on July 08, 2016, 02:20:44 PM
Quote from: ddavis20341 on July 08, 2016, 01:11:58 PM
Cheers!
Glad to hear. Enjoy bud.
