Hi,
I know Rabbit Hole is out, but I have two unused Mudbunny PCB's that I might as well use. Anyway, I use a breakout to wire the 3PDT, and I'm including two pics to make sure I'll be wiring things properly, (there are two inputs). Pic 1 is using Ben's breakout, (circles: do I need to include R25 since it looks like it's the LED CLR?). Pic 2 is using Barry's from Guitar PCB.com.
Thank you
You do not if you're going to use the one on the 3PDT board.
Thank you. My wiring diagrams on both boards is correct though?
Yep
