So, I'm in the final stages of Brejna's Pangea vibe and just ordered a drilled enclosure from PPP. I sent them one of my old-school hand-drawn templates with drill points measured from two edges. They wrote back a very friendly email asking if I'm able to re-do it with holes measured from the two center lines. Has anyone done one for this project in this way? I was going to try and hack it out in Photoshop or Illustrator using Bryan's Laserwolf as a jumping-off point. But if anyone has already done this it would be truly helpful.
Thanks as always!
Bret
Good to hear you are finishing Pangea vibe :)
I can send you corel project if it would help you?
Brane
Quote from: brejna on August 23, 2016, 08:53:02 PM
Brane
Could you link a pdf of it? I would be eternally greatfull
That would be great, Brane! Would I be able to open a Corel file with Adobe Illustrator? If not, a PDF would work fine as well.
Sounds like I'm not the only one that needs this! :)
Here is mine Corel Draw project https://www.dropbox.com/s/3twoek97s78qc57/voodoo2.cdr?dl=0 but I really don't know if it can be used by Adobe Illustrator. If not I will try to make something usable for you.
Quote from: flanagan0718 on August 23, 2016, 09:42:30 PM
Brane
If you mean build docs, here they are https://www.dropbox.com/s/xv1kguunn6bbe7q/Pangea%202015.pdf?dl=0
Thanks, Brane! I was not able to open that with Illustrator. Can Corel Project export to a PDF format?
Quote from: Bret608 on August 24, 2016, 01:05:31 PM
It can, here it is..
Cheers
That will help a lot! Thanks as always.
I'd be willing to lend my .ai file for my etch if anyone needs it. The pic for it should be on this site somewhere...
Thanks a million Brane! All I needed was the drill but you gave me much more. Thanks.
I am glad I could help :)
Cheers
