I finished up a glam build this evening and tried to bias the pedal. The lowest I could get the voltage was 7.3v. I couldn't get it down to the specified 6v. I tried the pedal and it seemed to work ok. I ended up using a bourns 3386 trimmer that is 50k. Could this be the problem?
I would test the trimmer out of circuit if possible
This happened to me, any ideas?
It's a bit unusual for a 50k trimmer to not be enough to bias, but going up to a 100k should solve the problem. To satisfy my curiosity - where did you get the 2N5457 from?
I got mine off ebay...bit of a newbie and its happened with a couple jfet builds, have wondered if its due to the transistor being el cheapo. ..
