General => Open Discussion => Topic started by: FuzzTony on October 21, 2016, 06:42:10 PM
Title: Quick Multimeter Trick for Measuring Small Capacitors
Post by: FuzzTony on October 21, 2016, 06:42:10 PM
Hi folks, thought I'd share something I just discovered.
I wanted to verify the values of some Tayda ceramic caps (10pF - 100pF range)  but my multimeter is not very accurate in that range.  47pFs were measuring at about 20p.  1nF and higher it has no problem and is accurate.
I thought about ordering a dedicated Capacitance Meter, but then I discovered a little trick.
I got accurate results for those small values by testing them in parallel with a box cap around 1nF.
Easiest for my setup is to use a breadboard with a 1nF cap across the multimeter leads, and then hit the "relative" button to zero it out.  I can then plug & unplug my little ceramics into the breadboard to my heart's content, and am getting accurate measurements.  Try it!
I just wanted to share this because I did not find any such suggestion in my online searching, only references to the unreliability of most multimeters in this low range.  The DIY solutions I did find were quite complex.  Cheers!
Title: Re: Quick Multimeter Trick for Measuring Small Capacitors
Post by: culturejam on October 22, 2016, 01:08:48 AM
That's a neat trick. I don't think any of my meters have a "zero" function, however. So I think you could get the same result by measuring the 1n cap first and then adding the other cap in parallel to see the change.
Post by: pickdropper on October 22, 2016, 01:33:40 PM
Yep, good advice.  I need to use the relative function on my Fluke 8 IV to get reasonable measurements of low value caps.  It's not as good as an LCR meter, but it is good enough to get by.
