General => Open Discussion => Topic started by: Micpoc on January 02, 2017, 11:58:32 PM
Title: On-Off Pot Switch for Onboard Buffer/Booster?
Post by: Micpoc on January 02, 2017, 11:58:32 PM
Hi all, and happy New Year.
I am considering building an MXR/CAE MC-401 stripboard clone (http://tagboardeffects.blogspot.com/2014/03/mxr-mc-401.html (http://tagboardeffects.blogspot.com/2014/03/mxr-mc-401.html)) to use as an onboard buffer/booster in a solid body guitar. There is plenty of room in the control cavity, and I already have a battery case installed.
What I would like to do is use a pot that acts as an on/off switch for the buffer/booster, i.e., when it is "off", the circuit acts as a buffer, and when it is on, it switches to "booster" mode, increasing gain as the pot is turned. I do not really know if this is possible OR what kind of pot to use for such an operation, other than a push/pull pot, which I'd rather not use. Is this doable? Would a reverse taper no-load pot, if available, do this? Thanks.
Title: Re: On-Off Pot Switch for Onboard Buffer/Booster?
Post by: mjg on January 03, 2017, 02:48:55 AM
What about using a pot with inbuilt SPDT switch?  They're quite common for off/volume on little portable radios, car stereos, computer speakers, etc.   Turn the pot all the way left, and it clicks off, changing the SPDT at the same time.
e.g.:  http://www.farnell.com/datasheets/1523874.pdf (http://www.farnell.com/datasheets/1523874.pdf)
Post by: Micpoc on January 03, 2017, 02:20:43 PM
That's pretty much what I was thinking about using; just have to find it in the labyrinth of Mouser.com.
