Projects => Tech Help - Projects Page => Topic started by: jimilee on April 01, 2017, 06:30:38 PM
Title: Honey dripper 2015 half works
Post by: jimilee on April 01, 2017, 06:30:38 PM
I have yeh and bow, but no wah and aehh
Which section did I screw up?
(https://uploads.tapatalk-cdn.com/20170401/878e47388087f885164fffbfab9d3b89.jpg)
(https://uploads.tapatalk-cdn.com/20170401/7b63359f612857778b1e089c70347ff7.jpg)
IC 3 Voltages are the only ones that are off
4.9
48
4.5
16.6
3.3
4.9
4.4
2.3
2.7
2.7
0
2.7
2.7
2.7
Title: Re: Honey dripper 2015 half works
Post by: madbean on April 01, 2017, 08:15:40 PM
I'll look over it more carefully later today. What diodes are those?
Post by: jimilee on April 01, 2017, 10:25:29 PM
Quote from: madbean on April 01, 2017, 08:15:40 PM
1n914
Post by: madbean on April 01, 2017, 10:31:10 PM
Yeah those are definitely not 1n914. They are from Tayda, aren't they? Not shaming...just verifying :)
Post by: jimilee on April 01, 2017, 10:32:01 PM
Quote from: madbean on April 01, 2017, 10:31:10 PM
They are, now I have to make sure.
Post by: madbean on April 01, 2017, 10:36:52 PM
That's going to be part of the problem my guess. If you need some 1n914 I can send you a handful. I have thousands. But, not sure that's all that's going on.
Post by: jimilee on April 01, 2017, 11:34:42 PM
Quote from: madbean on April 01, 2017, 10:36:52 PM
Yes please. I am utterly confused as to what I have then. I can completely agree with you.
Post by: somnif on April 01, 2017, 11:54:27 PM
Gulp, those look like the 914s I have as well... that I just finished populating a board with. Am I screwed as well?
Post by: madbean on April 02, 2017, 12:33:59 AM
The 1n914 is where a lot of the signal rectification happens on the envelope follower and those are some of the ones used on IC3. I'll go back and double check my voltages to make sure my list is accurate.
As far as those particular diodes, I have seen the supposed 1n914 from Tayda cause problems with other builds (specifically the Rustbucket). So, it's hard to say if that's the issue or not (without testing of forward voltage, etc, I can't really say for sure)...no question that those are not 1n914, though. In general, I advise NOT buying diodes/ICs/transistors from Tayda. You just don't know what you are going to get.
Anyway, I will re-check my voltages and give an update soon.
Post by: somnif on April 02, 2017, 12:49:02 AM
My Tayda yellow-band "914s" have a Vf of about .54-.56, which yeah... that's a bit low. Curses.
Post by: Stomptown on April 02, 2017, 01:03:55 AM
Quote from: madbean on April 02, 2017, 12:33:59 AM
Hmm.. Could other diodes like 1n4148s cause issues with the rust bucket? I'm pretty sure that's what I used and mine is extremely finicky. Sorry for the detail...
Post by: jimilee on April 02, 2017, 05:59:40 PM
If I touch R24 or R 25 on the right side, the effects each work, i'm stumped. You think that's the diodes too?
Post by: somnif on April 02, 2017, 07:42:42 PM
Quote from: jimilee on April 02, 2017, 05:59:40 PM
Do you have a cracked solder joint? I see you have dust covers on the pots but maybe they're shorting somewhere? I've no idea how poking a resistor would affect a circuit  :o Maybe something to do with that via between the two resistors.
Post by: jimilee on April 02, 2017, 07:43:35 PM
Quote from: somnif on April 02, 2017, 07:42:42 PM
It's grounding to me
Post by: madbean on April 04, 2017, 05:12:29 PM
Sorry for the lack of update. Went down with the flu on Saturday and it's been kicking my ass. I'll get them as soon as I feel up to it (starting to get a bit better).
Post by: jimilee on April 04, 2017, 05:21:47 PM
Quote from: madbean on April 04, 2017, 05:12:29 PM
No worries, I think I'm getting something now myself.
Post by: jimilee on April 12, 2017, 08:34:15 PM
Are 1n4148s interchangeable? They seem to come up when I search for 1n914
Post by: bsoncini on April 12, 2017, 08:56:56 PM
The guy who works at my local electronics store told me they were. He seems like he knows what he is talking about. I took his word for it and have never had a problem.
Post by: jimilee on April 15, 2017, 12:46:22 AM
Well, that did t work. I replaced the diodes with some genuine 1n914 and now I have no effect at all. I feel like there is an incorrect  resistor that  can't find.
Post by: jimilee on April 17, 2017, 01:43:27 AM
pin 1 of IC 1 is getting about 16v and I don't know why.
