Ok so I have a green bean 2014 model and Iam having trouble wiring it up. I have looked at the original overview of the project and it does not have a wiring diagram. Iam new to pedal building so any help would be great thanks.
You can use the new version of the build docs: the pads for wiring are the same, with the same labels, just located in a different place on the PCB. Only difference is in wiring the LED (new version has a board-mounted LED), but by looking at MB's tutorial on "Footswitch Wiring Essentials" you should be able to figure it out ;). (Note: the current-limiting resistor for the LED is already on your PCB as R20).
