Halp! :D
This is in the Sunking.zip archive which is linked on the Projects Page.
http://www.madbeanpedals.com/projects/ARCHIVE/OD_Dist_Boost/
Quote from: madbean on April 17, 2017, 08:20:43 PM
Thank you, Brian. The one I have isn't in there, unfortunately. It says Sunking 1 ver.2 (c)2010 on top, and appears to use all 1/8w resistors.
Just checking, do the part numbers line up with the other files?
Personally, I could figure it out, but I'm sending this to a beginner :)
Ah, okay. I made a mistake in the archive - I had the etchable layout named as the "fabbed" ver.2.
Okay, I have fixed the zip. The ver.2 you are looking for is now in there and labeled "ver.2". Sorry about that.
http://www.madbeanpedals.com/projects/ARCHIVE/OD_Dist_Boost/Sunking.zip
Quote from: madbean on April 17, 2017, 09:14:11 PM
Perfect! Thank you so much!
