i thought maybe i should start another thread since my problem is close to the other guys (in that it seems to revolve around ic2 pins 1 and 7), but not exactly the same manifestation. but it could be a board problem since it seems to be in the same area.
i just built 2 sunkings and am experiencing almost the same problem as the other sunking poster on both builds. both builds use the same parts. the problem sounds very close to that one, with the problem around the voltages on ic2-- pins 1 and 7 are off and they will vary as you rotate the gain pot with the sum of both always being in the 9v range (at the extreme pin1 will be 11v and pin7 - 2v or so, at the other extreme pin 1 will be maybe 7v and pin7 around 2) the differential makes the pot have a lot of crackling noise. the other voltages on the ic are as they should be. i swapped ic's, pumps, etc. but no dice. i also built one of these on a board i etched from the bajaman layout and did not have this problem---both voltages were around 4.5v and stayed steady with no change/crackle with rotation of the gain pot (same parts used). i'm thinking perhaps this might be a bad batch of boards with some trace short somewhere. any ideas would be very helpful----i hate to toss 2 boards full of parts. perhaps brian could look at a sample board from his last batch and see if there's anything obvious to him pad wise, etc. thanks very much. rh
Nothing obvious from looking at a few of the boards I have on hand. Since my build is out on loan to someone, I may have to build a new one up and check it out.
From what you are describing there are a couple of clues. 1) you've got DC across your gain pot 2) something is wrong in the vb supply.
Can you tell me how you are testing these boards? Are they loaded into an enclosure, or are you testing on a breadboard?
Have you used the correct voltage tolerances on your caps? Ideally, 25v or above on all, but at least on C20 - C22.
Any subs part-wise I should know about?
Of course, it is always possible that there can be a manufacturing error. These boards were electrically tested as part of the manufacturing process, so I guess there should not be any discontinuity in the traces. But, when debugging it's best not to rule anything out.
I do happen to have another person's built board on hand, so I can check that one out (most likely it will be tomorrow before I get to it). That may help provide us a baseline to work off.
Having built these layouts several times, I can vouch for their correctness. So, that's at least one possibility eliminated :)
For what its worth, I have built 3 of these with no issues.
Quote from: madbean on July 09, 2010, 03:29:44 PM
hey brian, i've used all 50v caps except a couple of the electrolytics (4.7uf and 47uf) are 35v, all the film caps are the panasonic, and 50v 1uf tant. there is dc on both the gain and treb. pots in the real klon (i have a real one here to compare it to). it's the differential from ref. that will cause the crackle. oddly, on my gain pot there is the correct voltage and no differential across the lugs which is correct BUT there is a differential across the treb pot lugs that seems to be controlled by movement of the gain pot (which crackles! until at full rotation--then i get a lot less gain and a muted tone, probably because pins1&7 are now at about 11v and -2v respectively)---just like the voltage differential at ic2 pins 1&7 (pin 1 being way higher than pin 7).
my builds are boxed up, but i can undo the pots and flip them back to test. any ideas would be appreciated. i build a LOT of tube amps so i'm more familiar with that stuff with regard to troubleshooting. but, some part/path short/something, etc. has caused the ic2 pins 1&7 to be severely offset from each being approx. 4.5v., though their sum is still about 9v. the ONLY thing that gives me suspicion about the board is that i have 2 builds doing exactly the same thing. rh
Okay, got it. I'll report back tomorrow once I've had a chance to get some of these orders back. We'll get it solved.
ok, looking at the schematic conceptually (from the pov of assuming no bad boards here, the ic's are good, etc.) what we have is the gain dual pot affecting with it's rotation the already messed up voltages on ic2 pins 1(too high) and 7 (too low)--and since the tone pot is between pins 1 and 7, that explains why it's floating voltages are off the same. since the sum of the two is around 9v and stays that way as they are altered by the gain pot, what part(s) causes these two pins to be in balance? what kind of fault could cause them to be out of balance? how are they balanced and how do they stay balanced in normal conditions? what imperfection pre ic 2 would drive pin1's voltage high, and would this drive pin7's voltage low? rh
Okay, this is a bit murkier than I thought. Are your readings on pins 3 and 5 on IC2 invariant under changes with the gain pot/tone pot? Are they the same, change inversely, etc? And, are they the same readings as pin2 of GAIN1 and pin3 of GAIN2?
Quote from: madbean on July 11, 2010, 02:38:48 AM
pins 3 and 5 on ic2 are unaffected by the gain pot rotation (they are 4.5v as they should be---and all lugs of the gain pot are invariant at 4.5v as well). btw, having just checked, pin7 on ic1 is also affected by all this---it drops from norm of 4.5v down to 1.4v as the pot is rotated. all the other voltages on other pins are as they should be. thanks for your help and suggestions man. rh
Quote from: rhinson on July 11, 2010, 04:32:38 AM
Okay, this is good info. I've got a build out and I'm going to take some voltages on it. I'll have more soon.
Quote from: madbean on July 11, 2010, 06:54:40 AM
hey brian, had a chance to look at anything regarding my problem here? thanks man, rh
Robert,
I will do my best to make that happen today. Sorry for the delay. Orders have stacked up due to my having to leave town unexpectedly for several days. But, I have a few debugging priorities to get to, including this so I will make an extra effort to give it some attention ASAP.
Quote from: madbean on July 21, 2010, 10:47:11 AM
Robert,
very cool--thanks very much. i'll try to succinctly summarize the problem by listing the problem voltages here:
gain pot at min: ic 1, pin 7--4.6
ic 2, pin 7--0.6
ic 2, pin 1--8.8
gain pot at max: ic 1, pin 7--1.4
ic 2, pin 7-- (-2.9)
ic 2, pin 1--12.6
in essence, turning the gain pot is rebiasing the ic's (with ic 2 starting from an already misbiased balance between pins1 and 7)---so i guess that's where the "crackle" comes from---kinda like the zvex sho pot. so there must be some part or bad connection condition that could cause this to occur---in the normal good build the turning of the gain pot doesn't affect voltage on these pins. thanks man rh
I've taken readings off two builds now. Here's what I have for the pins you mentioned.
IC1 pin7 - 4.46
IC2 pin7 - 4.46
IC2 pin1 - 4.46
Which is what I expected.
The first build I checked originally had readings that were way off on those pins. They were
IC1 pin7 - 8.29
IC2 pin7 - 7.74
IC2 pin1 - 1.26
The IC's used in that build were TL072CP and MAX1044. I replaced them with TL072CN and TC1044, resp., and got readings much more in line with my build. So, I'll need to do some checking into the CP vs. CN versions.
Also, I did not notice any voltage changes on those pins with either build, so this is all getting very interesting.
From what I can tell perusing datasheets, the CP vs CN has to do with thermal dissipation factors. That shouldn't be a problem, and either chip should work fine in this circuit.
Indeed, that's what I thought. But, the proof is in the pudding.
I have a few CP's on hand so I'll compare. Could be the first two are just crap.
Quote from: madbean on July 23, 2010, 04:03:11 PM
it's funny because i have jrc brand tl072's in one build and t.i. brand tl072cp's in the other and they both do the same thing (although the voltages in one are not off to quite the same extreme, it still has the same symptoms of the gain pot affecting the voltages in the exact same fashion). i also have 2 different brand change pumps, some of the electrolytics are different brands in each, most resistors are from the same batch but a few are not. the only constants are the panasonic film caps and the one tant. ---actually one of the film caps in one build is not panasonic, but all the rest are. even the dual 100k's are different (one is solder lugs from smallbear and the other is pcb lugs from somewhere else. i'm just looking for some place to start in terms of troubleshooting, given the symptoms and going under the assumption the board is good. my first/only instinct so far was to check the 2 1uf caps between ic 1 and ic but they both seemed to be doing their job. given all the interconnections here, i'm a little lost on what to check, and it still seem odd that both builds do the same thing. rh
The DC gain of the IC2B stage is -1, so pin 7 should follow pin 1 in an inverse relationship centered around 4.5v, which it seems to be doing, so I'd say that stage is correct.
If you disconnect GAIN1 and GAIN2, IC2 pins 1 and 7 should go back to 4.5v. IC1 pin 1 should be 4.5v and pin 7 should go to 4.5v, although it may drift.
Check that C16 is inserted correctly. It's upside-down from all the other polarized caps (except for C15 of course).
I'm still trying to wrap my head around how pin 1 of IC2 can go below 4.5v under static conditions. Can you post the voltages for all the pins on IC1 and IC2?
Quote from: oldhousescott on July 23, 2010, 08:44:03 PM
the rest of the voltages are not affected by the gain pot and are consistent with the voltages on my 2 good builds from the bajaman layouts i etched.
ic1 pin1 4.6 pin8 9.5 ic2 pin1(problem) pin8 17.2
pin2 4.6 pin7 (problem) pin2 4.6 pin7 (problem)
pin3 3.7 pin6 4.6 pin3 4.6 pin6 4.6
pin4 0 pin5 4.6 pin4 -9.1 pin5 4.6
also it's not pin 1 of ic2 that goes neg., it's pin7. pin1 goes from 8.8v to 12.6v, and pin7 goes from0.6v to -2.9v (both happen together at the same time as the gain pot is rotated from min to max.). thanks for thinking about this for me. i'll take any assistance. rh
OK, I'm guessing (hoping) the IC1 pin 3 reading is a typo. That should certainly be 4.6 like pins 2 and 1.
Anyway, IC2 pin 1 going positive kind of makes sense if IC2 is operating correctly and there's a short earlier in the circuit. I would still recommend checking the three 1uF caps to make sure they are installed with the correct polarity.
Quote from: oldhousescott on July 24, 2010, 11:01:49 PM
yes i've double checked cap polarity on both boards (remember i've got two sunking boards doing the same thing) and all is installed correct. and no the ic1 pin3 is not a typo. as a matter of fact, it's also the voltage i get on my other 2 successful builds on entirely different boards/layouts (bajaman) so it must be biased that way on purpose. rh
Oops, 3.7 is reasonable in this instance. The meter is loading the circuit.
Maybe check the voltages at the junctions of C16/R19 and C10/R16.
I just built one and tried it quickly, and it works fine. I used TL072CN and MAX1044.
All the parts comes from smallbear.
I've built up a new board, as well, from the same batch that's been shipping the past few weeks. Mine fired up right away and is behaving. The only sub was 1n60 for the germanium diodes. I'm not sure if I like those there....I think 1n34a or 1n270 "felt" a little better to me. I'm going to do a side by side with other other build to compare.
Anyway, here are the voltage readings on my new build, which are pretty much in line with the previous. I used a TC1044 and TL072CN as in all the previous builds I've done.
IC1
1 4.45
2 4.47
3 3.43
4 0
5 4.45
6 4.46
7 4.45
8 8.88
IC2
1 4.52
2 4.47
3 4.46
4 -8.46
5 4.45
6 4.46
7 4.41
8 16.03
IC3
1 8.88
2 4.55
3 0
4 -4.15
5 -8.47
6 3.99
7 5.33
8 8.88
I feel confident that these problem builds are isolated, be it through misbehaving components, build issues, etc., and not the fault of the manufacturer. I'll keep offering up what I can to help, however.
My build worked but I noticed I have forgotten to add Z1. I added and tested it, it worked ... and I cutted the excess with the power on (yeah stupid) ...
The bypass always works but when I switch on, it's like a tremolo (the led works). grrrrr
IC3 and C19-C22 are really hot.
IC3
1- 9.3
2- 0
3- 0
4- 0
5- 0
6- 4.5
7- 4.2
8- 9.3
I tried another max1044 (IC3) and I got the same values.
The pin problems are 2, 4 and 5.
All electrolytic caps are 50V except C18 which is only 16V.
Check cap orientation, remelt solder on the pads for IC3 and C-19-C22, and then recheck the voltages and see if you get a different reading this time. You are fine on C18 being 16v.
QuoteCheck cap orientation, remelt solder on the pads for IC3 and C-19-C22, and then recheck the voltages and see if you get a different reading this time.
I did this and it changes nothing.
Once again, my build worked but I did a stupid thing = cut the excess of Z1 with the power on.
Hot IC3 and caps (C19-C22), what does it mean ?
It's possible the caps got fried. Are the tops bumped out at all...like a little bulge?
They should definitely not be hot. It may require replacement :(
