Projects => Build Reports => Topic started by: pickdropper on November 06, 2017, 12:40:50 PM
Title: TimRay
Post by: pickdropper on November 06, 2017, 12:40:50 PM
A while back, a friend of mine asked if I would do a mini Jan Ray Vemuram.  Since I had already done a Timmy layout, I agreed to modify it and get a few boards made.  I finally got around to making artwork for it and building one up.  I really like the way the build looks, I'm still not sure I'm sold on the circuit yet.  So far, I prefer the Timmy, but I haven't played enough with this yet.
(https://i.imgur.com/0KzL1Ux.jpg)
(https://i.imgur.com/ZCLnw9J.jpg)
(https://i.imgur.com/FqLAjoi.jpg)
(https://i.imgur.com/ULnRQIX.jpg)
FWIW, this is my etching fixture for laser engraving.  The box screws to the fixture to hold it in a defined place.
(https://i.imgur.com/bwaifgq.jpg)
Title: Re: TimRay
Post by: brejna on November 06, 2017, 12:57:38 PM
Awesome build as always. Do you have spare pcbs, I would like to buy one if possible..
Cheers
Brane
Title: Re: TimRay
Post by: pickdropper on November 06, 2017, 01:11:45 PM
Quote from: brejna on November 06, 2017, 12:57:38 PM
Cheers
Brane
I have two or three.  I didn't buy many.  If you want one, shoot me a PM
Title: Re: TimRay
Post by: storyboardist on November 06, 2017, 02:40:37 PM
As always, that's a great looking build. Nice work with the engraver template too.
Title: Re: TimRay
Post by: flanagan0718 on November 06, 2017, 03:00:36 PM
MAN that thing looks perfect!
Title: Re: TimRay
Post by: BrianS on November 06, 2017, 03:18:26 PM
Awesome.
Title: Re: TimRay
Post by: Adam_DIY on November 06, 2017, 03:32:22 PM
Insane levels of perfection as usual.
Title: Re: TimRay
Post by: trotel on November 06, 2017, 03:42:56 PM
Looks beautiful!  I like how the rays bend over the top.
Title: Re: TimRay
Post by: m-Kresol on November 06, 2017, 05:47:29 PM
Love the simplicity of the artwork. still optically very effective.
Title: Re: TimRay
Post by: 287m on November 06, 2017, 06:37:56 PM
Amazing build as always
here the question came :D
are you always use flying wire the pots? and not stranded?
Title: Re: TimRay
Post by: pickdropper on November 06, 2017, 09:09:37 PM
Quote from: 287m on November 06, 2017, 06:37:56 PM
It is stranded wire.  I use 3-conductor stranded ribbon wire to go from the board to the pots.  It's Amphenol Spectra-Flex.  I used 4-conductor Spectra-Flex to go from the PCB to the 3PDT switch board.  The rest of the wire is Small Bear pre-bond wire.  That stuff is great to work with.
Title: Re: TimRay
Post by: Martan on November 07, 2017, 03:45:24 PM
Looks awesome! I love the depth around the laser work. Nice work on the jig for holding the pedal. Is there a defined spot for aiming the laser at or is it just the top right corner?
Title: Re: TimRay
Post by: juansolo on November 07, 2017, 10:25:57 PM
Stellar as always.
Title: Re: TimRay
Post by: pickdropper on November 08, 2017, 12:44:57 PM
Quote from: Martan on November 07, 2017, 03:45:24 PM
The laser itself always references to the upper left corner.  The problem with that is that there is a little bit of variability in the enclosures themselves, especially after powder coat.
The advantage of the fixture is that it puts the screws in a defined location so I can use the center of the enclosure as the focal point.  This theoretically will help center the artwork even if there is a bit of dimensional variation.
There is still the issue of the laser calibration itself changing over time.  The best way is to do a full recalibration of the bed regularly, but that's very time consuming and easy to get wrong.  Instead, I offset the fixture with a 1x1 spacer.  Periodically, I recut a new spacer.  Even if it's not truly at the 1x1 reference point, the software thinks it is so it still works.
Title: Re: TimRay
Post by: soldersqueeze on November 08, 2017, 05:16:16 PM
Your pedals are cleaner, prettier and better made than any production pedal i've ever owned. This is no exception. Wonderful work.
Title: Re: TimRay
Post by: playpunk on November 08, 2017, 06:47:42 PM
This is fantastic as usual
Title: Re: TimRay
Post by: Aleph Null on November 08, 2017, 08:30:15 PM
Love the bare metal peaking through the graphic! Did you mask off the enclosure and then paint, or paint the sides and use a decal on top?
Title: Re: TimRay
Post by: pickdropper on November 08, 2017, 11:30:49 PM
Quote from: Aleph Null on November 08, 2017, 08:30:15 PM
It was a fully powder coated enclosure and I removed the powder via laser.
Title: Re: TimRay
Post by: culturejam on November 09, 2017, 01:20:33 PM
Damn, that's sexy.
Title: Re: TimRay
Post by: pie.key on November 09, 2017, 03:34:20 PM
great build as always pickdropper!
if i may ask, how do you decide on which capacitors are multi-layered ceramics or film?
or just random?
Title: Re: TimRay
Post by: pickdropper on November 09, 2017, 11:32:42 PM
Quote from: pie.key on November 09, 2017, 03:34:20 PM
or just random?
My default is to use MLCC for less than 1nF as I can use C0G or NP0 caps (which work great).  For caps between 1nF and 1uF in the signal path, I prefer film caps, but there are times in the smaller builds where that isn't practical, so sometimes I use x7r MLCC caps.
For larger than 1uF, I usually use Electrolytics as they are usually not in the signal path.  Occasionally, if they are, I'll use MLCC caps there instead.
Title: Re: TimRay
Post by: Coda-effects on November 12, 2017, 07:40:22 AM
Nice! I really like these knobs, very clean build as usual I am impressed !
Title: Re: TimRay
Post by: pickdropper on November 12, 2017, 01:56:35 PM
Btw, thanks for all the kind words, everybody.  I appreciate it.
