Okay, my third madbean pedal in a row thats not giving me an effect..
Im starting to suspect that i am doing something fundamentally wrong
I get a bypass signal when the effect is plugged in, but im not getting an effect signal.
Also the calibration guide reccomends you set the clock rate coming from pin 2 and 4 of ic5 to 6.5k. The lowest i can get is to 7.5k
(https://i.imgur.com/GMHxbqy.jpg)
(https://i.imgur.com/7v2gHL5.jpg)
wiring
(https://i.imgur.com/tqT6nzb.jpg)
The clock issue is probably just an out of spec clock cap or delay pot, I wouldn't worry about that until you get the pedal working.
Voltages are needed to debug.
