I can't remember how long ago Alan sent us the boards for this... The PCBs has been built for about 6 months (Cleggy on the case for that). Finally I've got around to measuring up a template and squeezing it into a 1590XX.
What can I say, it's a Lovetone and they're very much their own effects :) It's also not finished yet. We've tested the stereo, the loop (reverse delay in the loop is awesome/bonkers), need to test the CV and maybe give it a final bias to make sure it's spot on.
I was more interested in it working properly inside than making it pretty... I'd also re-do the decal if I was doing it again as it's a tad hard to see.
Sweet 8) :)
I've tidied up the decal for it a lot. The new one on a coloured box (Orange would work nice) would look cool as. But, I ain't taking that apart now and drilling another!
Pretty epic!
And since it doesn't have a name you don't need to see the label too well anyway... ::)
What a monster! Brilliant work - almost tempting me to give that a go ...
Wow, that thing is a beast, and yet the wiring is so clean even with all those jacks!! VERY nicely done.
Hotness! Most impressive build sir 8)
By the way, make sure to have a good play with it in self-oscillation mode, that's a lot of fun!
It does some very odd stuff (Lovetone, to be expected), but the favourite for me has to be the reverse delay in the loop, it's oddness to a new level as every other repeat is backwards... Creates a trippy as hell effect as they sort of fade into each other.
Looks nice. Is it necessary to use shielded wire for this build?
When the wires are going right on top of the circuit boards (with all those lovely LFO and clock signals), yeah, it's a good idea. You'll notice that John didn't bother shielding the wires going around the edges.
Yep, what he said. That's the loop wiring so signal back and forward right over the top of the board. The chances of clock noise is very high there, so we didn't take any chances. The in and outs are routed well away from the boards so we didn't bother there.
Quote from: juansolo on July 08, 2018, 11:57:01 AM
Makes perfect sense. That's an excellent job with the shielded wire. I tend to avoid it unless really needed.
For me, it's a PITA.
Same.
The original pedal shields the line in, but in Alan's layout and how it's gone in this box, none of it is anywhere near the clock, so we didn't bother. I suspect in the original pedal it was however if it was necessary.
Lovely
You got the colour really a nice match to the real one, too.
Looking good Juan.
I've got the single sided, Keefe etched, version that I really need to man-up and finish. I've become very spoiled/lazy with board mounted pots and switches and this has neither....
I just placed an order for these, gonna be a long wait for them to be fab'd
(https://s22.postimg.cc/5dqnin0kh/lt_flange.png)
(https://s22.postimg.cc/3yp2u4241/lt_flange_db.png)
Quote from: juansolo on July 07, 2018, 01:11:08 PM
A true AlanP project, then.
I keed, I keed.
Came out great John.. but, it reminds me I have one populated that needs boxing.. ugh..
I need to get off my ass and start building again. lol
Looks great. I really enjoy mine but never got around to decorating or labelling the enclosure so I don't always remember what all the knobs do!
Quote from: selfdestroyer on July 09, 2018, 04:06:29 PM
These last few builds have been in the works for months, if not years! It's not good...
Quote from: PMowdes2 on July 09, 2018, 02:42:33 PM
Pretty mental looking board. Kudos.
sub'd
8)
Hey John.
Epic build but I must ask... How is the Time Out jack working out for you? Every build that I have done demanded that the Sleeve of the Time Out jack had to be connected to the ground bar on the other jacks. If I just wired it like the schematic (and like you have it in your pic), I would always get a horrible oscillation from the Time Out. Of course, this was only in stereo mode as the Space Out/Mono jack combines the two effects.
Have you seen this with your build as well?
The switched sleeve is connected to the common ground when it's not got a plug in there. When there is, it has it's own ground, the yellow wire on mine (I think using the transformer for isolation, guessing though, I'd have to look at the schematic). But if you read the manual to the original FWNN, there can be all sorts of problems with the general oddness of the whole thing with different setups. All I can say is that with what we tried it with, an MJW (Marshall 18W-a-like) and a Ampeg (Fender brownface deluxe I think...?) it was ok and behaved how we thought it should.
Quote from: juansolo on July 11, 2018, 08:37:23 AM
I just remember building mine and using them in stereo to 2 different amps and I would only get squeel out of the Time Out jack. I tried everything I could think of (swap amps, different instruments, different outlets for each amp, power conditioners, etc.) and with every build I would get the squeel from Time Out. Only thing that would get rid of it was to ground the Time Out jack Sleeve (along with it's respective wire.
Nice!! I'm in!
Wasn't happy with the decal so stripped it and re-decaled it. That wasn't fun, but much happier with it now.
Quote from: juansolo on July 22, 2018, 02:03:47 PM
That looks real nice!
Those "?"s remind me of the riddler.
That looks indeed much more snappy!
