Projects => General Questions => Topic started by: Ekimneets on September 03, 2018, 01:43:52 AM
Title: Footswitches: Which one and why?
Post by: Ekimneets on September 03, 2018, 01:43:52 AM
So this question is about Your go to footswitch, not special applications.
I want to know what you choose and why?
I geek out over quality, but is a $15 footswitch really justified. On the other hand picking up 10 for $5 off of eBay scares me.
I'm actually looking for a good balance of quality and fiscal responsibility.
I have no idea if  "soft touch" is desirable or that sort of thing or how important gold-plated lugs are?
-Mike
Title: Re: Footswitches: Which one and why?
Post by: jimilee on September 03, 2018, 02:09:44 AM
I use the gold contacts from tayda
Post by: somnif on September 03, 2018, 10:08:44 AM
My last couple batches have been the "Pro" 3PDT's from Mammoth. They were on sale for like 1.50 a piece so I bought a dozen. Lately I've been looking into opto/relay based set ups that use different switch types, and haven't settled on what to use for them really.
I've played with Tayda's soft touch spst stomp on my VFE builds and haven't had any trouble with it YET, but I can tell it does feel a little cheap. Thankfully given its design it will be easy to swap out if necessary (I use NASA style solder joins on them, straight wire soldered parallel to the pole piece, super easy to remove the wire that way)
Post by: Ekimneets on September 03, 2018, 01:39:02 PM
 I'm going to have to look that up, I have a hard time picturing it.
-Mike
Post by: jimilee on September 03, 2018, 03:16:07 PM
I think he means this
(https://i2.wp.com/makezine.com/wp-content/uploads/2016/03/Screen-Shot-2016-03-08-at-9.15.01-AM.png?resize=1200%2C670&strip=all&ssl=1)
Post by: matmosphere on September 03, 2018, 04:05:38 PM
Quote from: jimilee on September 03, 2018, 03:16:07 PM
Ouch!
Hahaha
Post by: pickdropper on September 03, 2018, 04:11:02 PM
I mean, it's so obvious.  Why would you need to solder in the CMOS battery on a motherboard?  It just snaps in.
Post by: Ekimneets on September 03, 2018, 04:15:11 PM
Somnif, those (pro 3pdt at Mammoth) are what I have defaulted to for now until something changes my mind. I don't think I'd go for anything cheaper than that, but I'm trying to figure out if there is any advantage on spending more. Or, is it more of a preference sort of thing.
Jimilee, I'm dense. When I get some time later today I'll look it up because I'm curious and because right now, I haven't got a clue what that's all about. Plus, NASA was mentioned and I grew up in Houston idolizing that organization. So, if it's good for them, then I'm sure I've got something to learn from it.
-Mike
Post by: matmosphere on September 03, 2018, 05:11:48 PM
I use the inexpensive ones from love my switches. They seem to be better than the tayda ones and on par with if not better than the standard ones at mammoth.
I think the tayda ones are okay too. They will all fail at some point or another but I haven't had any go bad for the past five years I've been building.
Post by: alanp on September 03, 2018, 05:26:20 PM
Quote from: pickdropper on September 03, 2018, 04:11:02 PM
Ignoring the elephant in the room (yes, he's soldering wrong), old motherboards did indeed have their batteries SOLDERED onto the board, not in a battery clip.
It can be a bastard when you open up an old 'pooter and the battery has leaked corrosive shit over everything around it.
Post by: reddesert on September 03, 2018, 05:52:26 PM
I'm guessing somnif means the style of passing the wire through the lug in the attached picture, as opposed to bending the wire around the lug (both are acceptable by NASA standards if done right).
NASA soldering standards are on the web, you can look at the inspection standards where I got this picture, http://www.sal.wisc.edu/docs/Soldering%20Basics.pdf (http://www.sal.wisc.edu/docs/Soldering%20Basics.pdf),
or the soldering technical standards document https://nepp.nasa.gov/docuploads/06AA01BA-FC7E-4094-AE829CE371A7B05D/NASA-STD-8739.3.pdf (https://nepp.nasa.gov/docuploads/06AA01BA-FC7E-4094-AE829CE371A7B05D/NASA-STD-8739.3.pdf). Few of us would literally solder everything to these standards.
Post by: jimilee on September 03, 2018, 06:52:51 PM
It was a bad and ironic rocket scientist joke.
Post by: Ekimneets on September 03, 2018, 07:38:04 PM
 Well let me put around the other way. If you were going to buy a pedal,  would you care what foot switch it had in it ?
-Mike
Post by: somnif on September 03, 2018, 08:00:21 PM
This is what I meant about my solder style on the soft touch switches:
(http://forums.pelicanparts.com/uploads15/lap+splice1253657256.jpg)
Just wire sitting next to the switch terminal, soldered in parallel. No twisting/hooking/anything. Wouldn't trust it on any part that experienced much in the way of physical movement, but in an enclosed box on my bedroom floor that I may want to re-work in the future, it seemed my best option.
(https://workmanship.nasa.gov/lib/insp/2%20books/links/sections/graphics/616/616-05.gif)
Post by: somnif on September 03, 2018, 08:13:29 PM
Quote from: Ekimneets on September 03, 2018, 07:38:04 PM
-Mike
I've had 2 pedals with switches die on me. One a pedal I built using a 3PDT I spent a ridiculous amount of money on from an electronic parts store here in town, and the other a commercial pedal (DOD with SPDT). The 3PDT pissed me off since it was like the 2nd pedal I built using a 3PDT (my prior experience had used DPDTs and millenium bypass style setups) and I'd spent something like 12$ on the switch, And it was a nightmare to rework.
The DOD pedal was easy to repair since they were generous with the wire length in the box, so I could just clip them, strip them, and wire in a new switch. That was... 6 years ago I think? And its still working fine with occasional stompage.
Post by: Ekimneets on September 03, 2018, 08:21:47 PM
This is why I love picking other people's brains. One, I've already learned a new soldering technique. Two, I pride myself on my tight builds with little, if any, extra length of wire. Never once, did I consider the need for repairs.
OMG, I've got so much to learn.
Mike
Post by: machfrequency on September 04, 2018, 01:10:46 PM
Quote from: somnif on September 03, 2018, 10:08:44 AM
Can anyone point me in the direction of an opto/relay switch seller/manufacturer?
1776 have a small PCB available to make one with a DPDT switch but It would be great to have a stand alone switch, like "The Gig Rig" OptoKick switches.
Cheers, Ben
(First contribution to this community, thanks everyone.)
Post by: Govmnt_Lacky on September 04, 2018, 08:28:39 PM
I have had 3 or 4 of the DPDT momentary footswitches (PCB pin) fail on me from BLMS. Funny thing is, when they failed... they failed as latching  :o
Post by: Govmnt_Lacky on September 04, 2018, 08:29:43 PM
Is this a woman in the pic? Wondering why "he" would be wearing such a large stoned engagement ring  ???
Post by: somnif on September 04, 2018, 08:47:58 PM
Quote from: machfrequency on September 04, 2018, 01:10:46 PM
Cheers, Ben
I can't find any pics of what the inside of the switches look like, but I can almost guarantee the switches themselves are momentary soft-touch with optical circuitry attached. I dug up the patent application for their "Quartermaster" board ( https://patents.google.com/patent/US20050056142A1/en?oq=US10%2f937%2c997 ) and it seems to use optical elements as muting/routing, pretty much as expected.
If you want something more compact than 1776's there is a switch-bottom sized version over at THCustoms: http://diy.thcustom.com/shop/optotronik_kit/
If you're looking for pre-assembled switches, that I'm afraid I can't help with. I have no idea where to even start looking for those.
Post by: machfrequency on September 04, 2018, 08:55:26 PM
Quote from: somnif on September 04, 2018, 08:47:58 PM
Cheers, Ben
Thank you friend.
I will look into it.
Post by: BryGuy on September 05, 2018, 03:43:11 PM
THCustoms has a lot of switching options and what is nice is he sells them in kit form. You get everything you need minus the switch. I've used the Optotronik sever times and they work well. Probably going to give one of his Uber Switches a try at some point; it's a relay/micro controller type.
If your looking for a relay bypass without a microcontroller PARASIT STUDIO (https://www.parasitstudio.se/store/p58/Relay_Bypass_PCB.html) sells such a pcb though I have not tried it myself.
Quote from: reddesert on September 03, 2018, 05:52:26 PM
A lot of good "what to look for" reference photos in that nasa document if you are concerned about your solder joints. A great reference source.
Post by: pickdropper on September 05, 2018, 04:27:21 PM
Quote from: Govmnt_Lacky on September 04, 2018, 08:29:43 PM
That pic has been around for years.  It is a woman in the pic.  It's a staged stock photo picture with somebody who clearly is not in it for their soldering experience.  ;-)
IIRC, most versions are watermarked by Shutterstock.
