Projects => General Questions => Topic started by: stevie1556 on September 06, 2018, 09:14:23 AM
Title: Pot help
Post by: stevie1556 on September 06, 2018, 09:14:23 AM
I'm trying to find a 10KC pot in 9mm size but I'm struggling to find one anywhere other then Smallbear. If I wired up a 10KA pot in reverse, would I be correct in saying that it will work the same as a C pot? Looking at a taper graph, I think that should be correct but I just wanted to make sure.
Title: Re: Pot help
Post by: Scruffie on September 06, 2018, 06:48:43 PM
Banzai have them, not cheap but they have them.
But yes you can do as you propose but the control will of course work backwards then.
Title: Re: Pot help
Post by: Aentons on September 06, 2018, 07:26:11 PM
https://www.taydaelectronics.com/potentiometer-variable-resistors/rotary-potentiometer/anti-log-reverse/10k-ohm-anti-log-taper-potentiometer-round-knurled-plastic-shaft-pcb-9mm.html
