General => Open Discussion => Topic started by: small fish on September 12, 2018, 09:32:33 PM
Title: CNC milling machines, low price?
Post by: small fish on September 12, 2018, 09:32:33 PM
Hi guys, I just found some old entries / threads for pcb cnc milling machines.
Because there´s lots of these thingies on ebay, I wondered if someone made some experience with these (cheap) machines.
Of course, they´re cheap (around 200-500 euros / dollars) and I don´t expect any high-grade-top-notch-stuff, but it´ll be interesting for me
if there´s any fair offer, which I could try for home usage.
So, I´d highly appreciate any advice on some valueable mills out there.
Of course, if there´s any actual thread, plz send me a link.
tia,
regards,
Carsten
Title: Re: CNC milling machines, low price?
Post by: madbean on September 13, 2018, 10:03:22 AM
I recently got a 3018 machine just to plunk around on. Mostly to do light duty stuff as I don't expect it to be that robust:
3018 Mini CNC (https://www.banggood.com/3018-3-Axis-Mini-DIY-CNC-Router-Standard-Spindle-Motor-Wood-Engraving-Cutting-Milling-Engraver-p-1274569.html?utm_design=41&utm_source=emarsys&utm_medium=Neworder171109&utm_campaign=trigger-emarsys&utm_content=winna&sc_src=email_2675773&sc_eh=d788274047be2f9c1&sc_llid=4872635&sc_lid=105229698&sc_uid=7xcurAP0bT)
The ER-11 collet (https://www.banggood.com/7Pcs-ER11-1-7mm-Spring-Collets-with-ER11A-5mm-Motor-Shaft-Holder-Extension-Rod-p-1209318.html?utm_design=41&utm_source=emarsys&utm_medium=Neworder171109&utm_campaign=trigger-emarsys&utm_content=winna&sc_src=email_2675773&sc_eh=d788274047be2f9c1&sc_llid=4872635&sc_lid=105229698&sc_uid=7xcurAP0bT) seems to be a must for upgrades to the 3018.
This machine might be okay for some PCB milling or faceplates. Not sure about engraving directly to enclosures...maybe? Unfortunately, I haven't had time to put it together yet so I can't give you any good advice on it. But there are a lot of youTube videos about this machine and similar ones.
Post by: sturgeo on April 10, 2019, 08:45:41 AM
Quote from: madbean on September 13, 2018, 10:03:22 AM
Any chance to try this machine out yet? I'm after something for drilling pilot holes in enclosures before opening them out on a pillar drill.
As i'll be using a regular drill bit rather than end mill and only making plunges i'm hoping the lateral forces involved won't expose the weaknesses of these machines.
Post by: Aristatertotle on April 12, 2019, 04:53:14 PM
Is it a repeatable design that you're waiting to do, and only for pilot holes?
If so you may want to just look into getting something like a drilling template fabricated instead. Even with using drill bits, the z axis will only be able to exert so much pressure on them for anything even as small as like an 1/8"/ 3mm bit, so it'll be pretty slow going most likely with the small machines, and that's not when accounting for setting up a fixture to align/hold the enclosures in the same spot.
Might be more frustratingly slow than the precision is worth basically.
