Projects => General Questions => Topic started by: DLW on October 09, 2018, 11:13:01 PM
Title: PedalPCB Duo-phase
Post by: DLW on October 09, 2018, 11:13:01 PM
I am getting a normal effect out of phaser A (right, component side up). Phaser B passes signal fine, but the pots have no affect on the rate or depth. The board has not been put in an enclosure yet, so the switches are not soldered in place. Would this be the cause? If not, are there specific components I should check?
Thanks,
Darin
Title: Re: PedalPCB Duo-phase
Post by: somnif on October 09, 2018, 11:46:32 PM
The switches are what connect the LFO to Phaser B. So without them soldered into the circuit, you essentially have a static filter in place from that half of the board. No phasing, just a big complex fixed tone knob.
Post by: DLW on October 10, 2018, 12:10:33 AM
thanks! I'll drill the enclosure and solder the switches.
