Im new, so forgive me if this is posted in the wrong place
I'm currently building 2 aquababies and I'm struggling to find a 1590B enclosure with the correct layout for the pedal. I emailed Brian and he said my best bet would be to ask the forum - so does anyone here do custom enclosures? Or can you direct me to someone who does reasonably priced custom enclosures?
Thanks y'all!
If you can gain access to a hand drill, a step bit, a center punch, a printer, and some tape, you can drill your own. Otherwise, you might look at Mamotth (http://www.mammothelectronics.com/collections/custom-enclosures) or Pedal Parts Plus (http://www.pedalpartsplus.com/Drilling-s/156.htm)
where are you located?
As you're using wired pots, according to the current aquababy pdf on the projects page, it's be just as easy to get a pre drilled, prepainted 125b from Tayda. They're for pedalpcb boards, but you can use them easy enough.
Quote from: Willybomb on August 21, 2019, 08:50:55 AM
Thanks Willybomb!
