Projects => General Questions => Topic started by: benny_profane on October 02, 2019, 03:41:03 PM
Title: Remove burrs from knob inner shaft
Post by: benny_profane on October 02, 2019, 03:41:03 PM
I've got some knobs that have burrs around the set screw holes. What is the best way to remove these short of muscling the knob onto the pot shaft?
Title: Re: Remove burrs from knob inner shaft
Post by: EBK on October 02, 2019, 04:48:39 PM
Hobby (Xacto) knife?
(https://images.homedepot-static.com/productImages/8fd8ae79-5355-4a2b-a86a-937ff5c4b3ea/svn/stanley-utility-knives-10-401-64_1000.jpg)
Post by: benny_profane on October 02, 2019, 04:54:31 PM
Haha oh man, yeah I'll have to give that a shot. Another issue: the specs on these state inner diameter of 6.4mm (so fit for 1/4" pot shafts), however, it is rather tight. I don't think these are 6mm because they wouldn't even begin to fit, right? I suspect I might have to slightly ream these out? If that's the case, I'm not sure how best to proceed.
Post by: EBK on October 02, 2019, 04:57:52 PM
Use a 1/4" drill bit to ream them out by hand.  But, wrap some tape around the shaft of the bit so you don't slice up your fingers.
Post by: benny_profane on October 02, 2019, 05:03:42 PM
Quote from: EBK on October 02, 2019, 04:57:52 PM
Good call! Hopefully this'll work it out! I've got a handful of knobs with this fit problem so this could be the trick to get them all in workable order.
Post by: pickdropper on October 02, 2019, 05:55:46 PM
This.  Better yet, get a 1/4" end mill bit.  It's flat on top and works a bit better.
Post by: benny_profane on October 02, 2019, 06:29:52 PM
The drill bit worked perfectly. I just attached it to a vice, inserted the knob, turned a few times, screwed the set screw in and out, repeated the process, and cleaned it out. There was quite a lot of excess material in there.
I'll keep the mill bit in mind. I don't have one on hand, but that does look like the perfect tool for the job.
Thanks all!
Post by: alanp on October 02, 2019, 10:03:23 PM
Where are the knobs from?
Post by: benny_profane on October 02, 2019, 10:51:26 PM
Quote from: alanp on October 02, 2019, 10:03:23 PM
An eBay seller of some winged Marconi knobs.
