Projects => General Questions => Topic started by: Philthy on December 16, 2019, 10:51:52 PM
Title: Bumblebee: sub TC1044SCPA for a LT1054?
Post by: Philthy on December 16, 2019, 10:51:52 PM
Hi Guys,
Is an LT1054 a direct sub for the TC1044SCPA in this circuit?
Cheers
Title: Re: Bumblebee: sub TC1044SCPA for a LT1054?
Post by: madbean on December 17, 2019, 01:13:24 AM
You should be able to, yes. Although you do not need to connect pins 1 and 8 for the LT1054 (you do for the TC) I don't think there is any harm in doing so. Or, you could simply remove the socket pin from pin1 if you are using a socket. I think either is fine.
Post by: Philthy on December 17, 2019, 02:53:05 AM
Quote from: madbean on December 17, 2019, 01:13:24 AM
Thanks for the response madbean.  It's already socketed, so just lift pin 1 on the LT1054 right?
