General => Open Discussion => Topic started by: Bio77 on December 29, 2019, 07:17:26 AM
Title: Tayda Grey Box Caps??
Post by: Bio77 on December 29, 2019, 07:17:26 AM
Populating a board, and realized I don't have enough 82nF caps.  I do have a bag of Tayda 82nF caps, I bought a couple of years ago.
The manufacturer, according to Tayda, is Acutronics, which I learned from the inter-web is Kemet.  Does anyone have experience/opinion of these caps?  They are battleship grey with few markings.
The pedal I'm building is an overdrive that I want to sound right. I'm might order some Topmay caps from Small Bear, but don't know these either. Opinions appreciated!
Title: Re: Tayda Grey Box Caps??
Post by: chongmagic on December 29, 2019, 07:26:36 AM
I have used quite a few of those when an odd value comes up. I always measure my components with a DMM to double check before I install them and they have been pretty good. I haven't experienced any issues with them. I say as long as they measure the correct value you should be good to go.
Sent from my SM-N975U using Tapatalk
Post by: somnif on December 29, 2019, 06:48:34 PM
I've used them in most of my builds over the years without issue. Granted I'm a bedroom player, so not exactly a robust test of the rigors of stage life.
Post by: Bio77 on December 30, 2019, 12:06:00 AM
Thanks for the input.  I always go down this rabbit hole with caps. I'm not convinced any of them sound different, but there is so much effort into building a pedal that I don't want to risk it.
Post by: Aentons on December 30, 2019, 12:24:44 AM
I don't wanna hijack the thread, but now I have the burning question of... other than tolerance, just how would a subpar film cap present itself?
Post by: chongmagic on December 30, 2019, 12:31:53 AM
It would be that one who hung out at dockside bars, and always ended up sleeping on your couch
Post by: Bio77 on December 30, 2019, 01:56:55 AM
Quote from: Aentons on December 30, 2019, 12:24:44 AM
I'm curious too.  I know ESR is something that can be measured, not sure it's important for audio signal.
Post by: lars on December 30, 2019, 06:49:32 AM
Most humans don't have the ability to hear the difference. But there are those very special audiophiles that have hybrid cat-hearing that can tell the difference at around 50 kilohertz. So many dissonant harmonics up there...I spilled my wine!
Post by: pickdropper on December 30, 2019, 02:55:42 PM
It wasn't in a guitar pedal application, but I had an amplifier that had too much DC offset (measured).  I switched to film caps that had a lower dissipation factor and that improved (again verified by measurements, not by listening).  In that case, the caps were less expensive, so there's that.
There are differences between polyester and polypropylene caps, but it's application specific.  For the majority of pedal applications, it probably doesn't matter.
