Projects => General Questions => Topic started by: mas_picante on May 22, 2020, 10:01:07 PM
Title: ManOWar Power Supply
Post by: mas_picante on May 22, 2020, 10:01:07 PM
I have a ManOWar board populated, ready to fire up but... It's positive ground right? I've gone through the build report like 6 times... I might be missing it. The drawing in the offboard wiring isn't very clear like most projects are.
Thanks for you help.
Title: Re: ManOWar Power Supply
Post by: jimilee on May 22, 2020, 10:12:03 PM
nope, the BOM doesn't say anything about positive ground.
Post by: mas_picante on May 22, 2020, 10:21:00 PM
Thank you. I thought the AD900 was, but I'm probably thinking of the DMM.
Post by: benny_profane on May 23, 2020, 02:08:10 AM
Quote from: mas_picante on May 22, 2020, 10:21:00 PM
The Maxon AD-900 does use a positive center 12v supply. The Man O' War (DX) uses a center negative 12v supply, though.
Post by: Cybercow on June 07, 2020, 04:22:48 PM
Did you build your Man-O-War for 9v or 12v operation? Either way, both power supplies are negative center.
