Projects => General Questions => Topic started by: ogguitar on August 24, 2020, 05:22:18 PM
Title: Afterlife Nasty Clipping
Post by: ogguitar on August 24, 2020, 05:22:18 PM
Got the Afterlife on my breadboard with the Ghost Note mod, and I'm getting clipping that sounds like a starved voltage fuzz/OD of sorts, and the sustain and sensitivity controls don't seem to work properly. I'm a bit puzzled about this one as I've double checked the circuit, connections, and component values several times. Any possible leads or tips are greatly appreciated. Cheers!
Title: Re: Afterlife Nasty Clipping
Post by: midwayfair on August 24, 2020, 06:20:36 PM
Post pictures and voltages please.
probably want to link to the mod, too, even I don't remember exactly where that post is ... :)
Post by: ogguitar on August 26, 2020, 01:40:19 AM
Here you go. Thanks for the help!
https://drive.google.com/file/d/1jJo9mGtU8UiblM5ofhBwo4obNSCsGC2R/view?usp=sharing
My IC voltage readings
1 7.53
2 8.90
3 4.37
4 0
5 8.93
6 6.77
7 7.62
8 9.04
Mod is R7 (47k) swapped for 24k in series with B50k pot as you've described. Here's how I hooked it up
Quote from: thesameage on January 09, 2015, 03:03:21 PM
For anyone wondering, here's how you do the Ghost Note mod:
Connect lugs 2 and 3 of the pot. Solder one side of the resistor to lugs 2/3, and the other side goes to the PCB. A wire from lug 1 of the pot goes to the other resistor hole on the PCB. Order doesn't matter. You could use a 100K pot without the limiting resistor (or even larger) instead if you like, but I found the 50K + 24K gave plenty of range.
I used a linear so that noon was the original value, but feel free to deviate!
Post by: midwayfair on August 26, 2020, 02:39:01 AM
pin 5 is connected directly to Vb in the schematic, which should put 4.5V on that pin -- you have it almost at 9v. Trace all your power connections starting with the 9V.
Post by: ogguitar on August 26, 2020, 04:38:56 AM
Ah yeah I had R9 going to VB instead of to IC 4. Thanks a bunch!
There still seems to be a fair bit of breakup (much nicer sounding now though) at higher sustain levels, but I've been using a guitar with pretty hot humbuckers. For now I've just turned the sensitivity knob all the way down and backed off the sustain until it cleans up a bit. The compression sounds quite nice!
Post by: ogguitar on August 27, 2020, 04:54:39 PM
Just in case anyone ends up following this, I addressed the clipping primarily by using a different optocoupler. The cleanest ones I have seem to reduce overall volume a fair bit. Unity is basically max on the A100k pot, but it's ok imo because I'm never really looking for a compressor to boost my signal. Though if anyone has tips on how to increase the make up volume available I'm all ears.
I also stumbled across this write up which I found very useful to make the circuit a little friendlier to different opamps, among other things.
https://atomiumamps.tumblr.com/post/158891400886/hollis-flatline-compressor-modsupdates-ive-built
Lowest noise I have is a NE5532 which is dead silent even with everything exposed on a breadboard. The LM833 has lower noise than the TL072 as well, and it seems to be the squishiest of the bunch so far. I'm not sure which I prefer yet. I've also swapped the bridge diodes to 1N5817 as I have a few extra, and I want to save the germaniums for another project.
