Projects => VFE Projects => Topic started by: mweb47729 on September 22, 2020, 10:30:56 AM
Title: VFE drill guide for top-mounted audio jacks?
Post by: mweb47729 on September 22, 2020, 10:30:56 AM
Would a 125B accommodate top-mounted jacks for VFE projects?  This previous post seems to imply it would.
https://www.madbeanpedals.com/forum/index.php?topic=26058.0
Was the drill guide mentioned ever made?  The guides in the zip file still show side-mounted jacks.
Title: Re: VFE drill guide for top-mounted audio jacks?
Post by: jimilee on September 22, 2020, 12:55:44 PM
I believe the drill guide is in the V3 of the switch board BOM. Almost positive.
Post by: mweb47729 on September 22, 2020, 01:15:22 PM
The drill guides I see in both the pdf and psd show side-mounted jacks.  Is there another source I should be referring to?
Post by: madbean on September 22, 2020, 01:27:55 PM
After I looked at it some more I decided that top mounted jacks are probably not going to work for many of the builds. There are too many builds that have ICs and caps that would block proper jack placement. I'd stick to side mount.
Post by: mweb47729 on September 22, 2020, 01:49:41 PM
Will do side mounts.  Thanks for the response.
