Is it just temporarily out of stock, or is it being discontinued?
It's not discontinued. I'm happy to get some more. There just hasn't been any demand for it since it ran out several months ago so I haven't re-stocked it.
Anyway, I am placing an order this coming week so I will put in for some ManOWar at the same time.
Wow! Great, thanks Brian. Can the Deluxe be wired up without the modulation? I have not looked closely at the PDF for it.
Quote from: Micpoc on February 21, 2021, 02:36:24 AM
Sure. Just omit the entire LFO area that starts at R54 and ends with the Depth pot and LDR. If you do that you still have the the same delay time but no modulation.
Quote from: madbean on February 21, 2021, 02:50:36 AMSure. Just omit the entire LFO area that starts at R54 and ends with the Depth pot and LDR. If you do that you still have the the same delay time but no modulation.
Thanks. Does that mean everything in the lower left portion of the schematic, i.e. R54–63, C41–43, IC7, RATE pot, T/O/S switch, LED3, D4, LDR, and DEPTH pot? No jumpers necessary?
I tried uploading an image to illustrate, but it would not appear in the preview.
