I had NO idea how much Mouser has apparently changed in the last few years, and I am now looking at spending a boatload of $$$ to get the ⅛w resistors for a Man O' War Deluxe. I've had spotty luck with Tayda resistors values in the past; Small Bear would probably be over $60 for all the values I need; and the Vishays at Mouser are about the same size as ¼w. Any ideas?
Barring that, will I have to use ¼w and stand them up?
Looking at the board in the pdf it looks to me like standard resistor spacing for 1/4w's, no need for something physically smaller.
Quote from: davent on February 22, 2021, 11:18:52 PM
There are two 1/4w's, but everything else is smaller; this is indicated in the Shopping List.
https://www.madbeanpedals.com/forum/index.php?action=dlattach;topic=31052.0;attach=22030;image
Quote from: Micpoc on February 22, 2021, 11:27:26 PM
Google found me a Man O' War pdf and ignored the Deluxe in the initial search, you have the Man o War Deluxe which i now see is quite different.
https://www.madbeanpedals.com/projects/_folders/Delay/pdf/ManOWar.pdf
You might look at 1/2w & 1/6w resistors too that come in the same size factor as the 1/8w.
Quote from: Micpoc on February 22, 2021, 11:04:35 PM
I've bought quite a bit of tayda 1/8 watt resistors and had no problems. On the rare occasion they don't have a value I usually teepee in series two values to get what I need. Or you could just get that odd value they don't sell from smallbear.
There is absolutely nothing wrong with Tayda resistors, in my experience. I measure every resistor before it goes on the board. Thousands of resistors without really any of them being out of spec.
I've used Tayda resistors for about 3 years now with no problems. The "Royal" ones they offer have thick leads and I can't detect a noticeable difference between those and Xircons.
Yeah, I am just going to go ahead and order from Tayda. Now that I think of it, it was probably caps that I had some trouble with, not resistors.
When did Mouser start having this 200 resistor minimum? I've been a little out of the loop for the last couple of years and have not kept up.
