I'm starting to plan out building a handful of tone bender variants. I already have a mkii pro that I built a couple years ago. I've been wanting to do a mkiii and/or a park fuzz, so I have a pastyface and an aion phobos board. Maybe I need a second Phobos so I can do one as a mkiii and one with the park specs. I also have an aion poseidon board to do the catalinbread katzenkonig thing. I need to snag a dustbunny and a bumblebee, which are sitting in my cart right now.
I should do a mki for good measure. I can get a pedalpcb tone vendor I guess. Looks like small bear doesn't have matched transistors for mkis currently, so that might prove to be a little tricky. I also want to do a, EQD black ash so I'm looking at the pedalpcb carbon black.
What other tone bender family projects should I look at? I'm aiming to do all these at the same time so I can try them all out. Might be a little nutty. I hope I can finish them all before the end of the year, along with everything else I want to do
Hint: you can replace the first transistor in a MKII with a FET.
The Burns Buzzaround and it's meaner twin, the Elka Dizzy Tone, are both pretty closely related to the Tone Bender Mk III. I'd definitely recommend checking them out!
Anyone see the crazy money the Boss Waza version is going for on Reverb?
I made the DAM Solasound MKII Si/Ge hybrid from a layout on Dirtbox Layouts and it sounds really good, there's actually a good range of dirt in there. I used a GT404 in mine. http://dirtboxlayouts.blogspot.com/2019/10/damsolasound-tonebender-mk-ii-hybrid.html
There's also a layout over there for a SolidgoldFX Rosie silicon MKII, which is a pretty good sounding variant. http://dirtboxlayouts.blogspot.com/2020/09/solid-gold-fx-rosie.html
I have built a mk1, 1.5, 2, 3 and the scarab deluxe as well as a dizzy tone and buzzaround. I got all my sets of transistors from small bear and can give you hfe and leakage for whatever you need, assuming you have a bulk lot of transistors to sort thru.
Quote from: Thewintersoldier on April 28, 2021, 12:40:33 PM
Hi! Can you give good values (hfe, leakage, etc) to make a great sounding MKI? The MKI is the only one I haven't built yet and the info on the web leaves for a lot of guess work and assumption.
Quote from: danfrank on April 28, 2021, 09:42:18 PM
Seconded. I think this is gonna be the tricky one
No problem I'll do it this weekend. I built it on a pedalpcb board. I decided to change out the Q3 bias resistor with a trim pot to dial it in. Other than that it was stock values.
Quote from: Thewintersoldier on April 28, 2021, 11:28:10 PM
Chrism the fuzz man... great stuff.
I'd actually be keen to get your take on hfe and leakage on all of those circuits, as a reference on here. There seems to be a fair bit of discussion and some confusion around, so having your take here as a reference would be great since you have been on a Fuzz binge recently.
Also, what tester do you use to measure or do you rely on given values by vendors/Smallbear etc?
Last not least, which schematic did you use for the Dizzytone, I believe I have seen some different ones, might be wrong, not sure. Have you got a link and how did you like that?
That's enough questions for the day I spose... ;)
Cheers!
I highly recommend the basic audio scarab, covers a ton of bases and is super easy to build.
Cool I added the scarab to the list. Really appreciating all the input here guys
Quote from: cooder on April 28, 2021, 11:44:00 PM
Cheers!
https://www.madbeanpedals.com/forum/index.php?topic=30992.0
This is the thread from last year where I detailed the changes from a buzzy to a dizzy. I'm actually planning on doing another buzzaround so I'll have a build report coming on that soon. I'll pull all my tonebenders and buzzaround/dizzy tones and do an actual reading on hfe/leakage. As for testing I built the R.G. Keen tester. I use it for both npn/pnp and si/ge transistors. I get great results with a bit of mathematics but it cost me pennies to build. I did the same with my jfet tester. I build them on the free samples of flooring from home improvement stores lol. When I do readings I wear insulated leather gloves (OJ!) So I don't warm up the transistor and wait 5 mins after powering it up as I know handling and power can affect germanium, silicon just let it rip. As far as schematics I look for vintage . If there are different revisions I look for the most common. Also anything David Main at DAM pedals has made is the gospel as far as fuzz so his schematics are golden as well. Lastly Kevin at aion has outstanding build docs with great substitutions for variants of circuits as well as transistor specs and biasing. (https://uploads.tapatalk-cdn.com/20210429/aca1548ab94baec6827cb0ad72cb5fa2.jpg)(https://uploads.tapatalk-cdn.com/20210429/6c3e690c685c388df4bd6fc1c671aa71.jpg)(https://uploads.tapatalk-cdn.com/20210429/5959b06347112d0483b885d3b61742c6.jpg)
Sent from my Pixel 5 using Tapatalk
Cheers Chris for the hints and wisdom!
Yes I have built the R.G, Keen tester as well and I use the Chinese component testers you can score on evilbay et all for a 'second' opinion and they are great to check pinouts of unknown or dubious stuff.
This component tester is not too bad I think and it's what I use:
https://www.ebay.com/itm/233902185469?hash=item3675a81bfd:g:snAAAOSwwiFf7BJn (https://www.ebay.com/itm/233902185469?hash=item3675a81bfd:g:snAAAOSwwiFf7BJn)
Also there's a Excel spreadsheet which is convenient to the max to put the test measurements form Keen method in, you'll find it as a link at the bottom of first (duhvoodooman) post here:
http://www.byocelectronics.com/board/viewtopic.php?f=9&t=38231&hilit=transistor+spreadsheet (http://www.byocelectronics.com/board/viewtopic.php?f=9&t=38231&hilit=transistor+spreadsheet)
Basic skill for all transistors setting is to play with feedback resistor (here resistor with *) to get at output point (here Collector) DC value which is cca 1/2 of Ub. All transistors must to be "heated" by this and in most of circuits here goes at Basis some set of resistors: 1/ from output point, or 2/ from Bias power souce or from Ub via 1from bias or 2 resistors from Ub at ground. In the centre here is bias for Basis. See pictures. In the case of multi-level stage of transistors amp here is important output transisitor DC value. It all is very briefly but sufficient for good working.
Hey Chris, let us know if you get a chance to check the gain and leakage on your mki transistors
Quote from: harryklippton on May 14, 2021, 09:48:21 PM
I just rigged up a new tester last week too. I'm at gymnastics with my youngest daughter. How about I get gains for mk1, 1.5, 2, 3 and the buzzaround and dizzy tone. I'll post tomorrow at some point.
That would be awesome if you can swing it!
I said I would do it, just took me a little longer to get to it. I hate adulting and that's all I've done this weekend and will do all day. I snuck some time in last night. These are done with the rg keen method so I'm sure an peak dca75 will give better results. I want to get one and just might for jfet usage as well. Anyways...heres wonderwall.(https://uploads.tapatalk-cdn.com/20210516/4422c406026117165197e24aa31f3b93.jpg)
Awesome! Thanks a million Chris!
Cheers Chris, much appreciated that you wrangled time for this!
No problem guys, all sets were bought from smallbear. My wife worked all weekend so I had the kids as well as things to do around the house. Cleaned out the garage some, cleaned the gutters, trimmed all the bushes and did the usual yardwork. Got the grocery shopping done as well as 4 loads of laundry on top of my usual cooking and dishes and all that. And back to work in the morning.
It does my heart good to see Smallbear offers correct specs for the MkIII. Over the years I've seen lots of people post on forums saying they're not satisfied with a MkIII build (usually saying it's too blown out or farty sounding), and pretty often it turns out they used transistors that would make more sense for a MkII. The MkIII (and Buzzaround and Dizzy Tone, for that matter) likes low gain and leakage on Q1 and Q2.
The MkI is a weird one for sure--try to find the posts from luciferstrip over at DIY Stompboxes where he lays out how to select transistors and tune the circuit to your liking. For example, more leakage on Q3 will give you longer sustain, whereas less leakage makes it more gated.
Hi, Harry Klippton. If you want play with Tonebender to understand, how it works inside, I can offer Adjustable SuckFuzz, with the same core inside! See and enjoy for your own setting!
Looks cool thanks Zerro!
